Nice... I like the Mavic wheels. Mind I ask, when you buy the Mavic wheels system, do you have to buy the tires separate or are they included with the wheel set.?
The Mavic wheels come with tires. These are called Crossmax Enduro and they're $1000. So it's like $850 for the wheels assuming you like the tires.
The tires are awesome when I rode them at Trestle, Winter Park for a few days. The front is big and soft at 2.4 and the front rim is 21 mm internal. The rear tire is 2.2 with a faster pattern and harder compound and it matches up to a narrower 19mm internal width rear
Not really, just trying different sets. It's not a bad idea since these tubeless wheels take some work to seal perfectly and it sucks to change tires and ruin a great seal.
But I think I'll just put an aggressive tire on this bike at all times. If conditions call for a faster climbing tire, I'll just use a faster bike.
I have the same talas 160 fork on my mach 6. Curious what psi and rebound are you riding? What SAG do think works best on it?
I am about 170 trail weight.
Although I just got this 160mm 2014 Fox Talas Kashima and it is wayyyy supple.
The rear of this bike is a true winner. and having the best rear shock today, the Fox Float X adds to the magic.
fc
Wow! Gorgeous bike Francis. Not sure how I missed this thread when it first came up.
I've said it before, but I think the new kashima '14 Fox 34 is a pretty sweet fork. I've yet to ride a Pike that felt appreciably better. Having said that I'll probably go with the Pike when I build up my next bike this Spring.
Looking forward to your full report in the Enduro round up.
Isaiah 58:14
Hey guys,
havent found the right place for my questions, so im gonna post it here.
Im gonna build up my brand new Mach6 Framekit in a few days and need your advice.
Its my first carbon frame.
So first of all:
Ive bought a GXP Pressfit bottom bracket and a used X0 DH GXP 68/73mm crank, do i need any spacers for the bb or shells right into the frame?
How do you guys mount your brackets? Do you used grease or loctite?
Same goes for the headset. Grease or loctite?
Is ZS44/ZS56 the right size?
