Results 1 to 34 of 34
    Reputation: Ineedmorecowbell's Avatar
    Jun 2010
    Mach 6 plus Stan's hub plus XO cassete equals chain rub on inner seat stay
    Getting ready for my first ride and noticed this. It seems way too close, zero tolerance. Am I missing something here? When I tighten the rear axle all the way it leaves almost zero room between the cassette and the frame. Followed Mr. Stans directions to the T when changing axles. Wtf ?? Can someone help?????
    Jun 2010
    I don't know if this helps but I bought this second hand a friend of a friend deal. Basically bought the frame and rear axle. Dude moved up to a large not sure I got everything I need.
    Jun 2010
    I am going to to buy a $329 pre built rear wheel tomorrow to send if it helps. Crossing my fingers
    Reputation: Joel RW's Avatar
    I'm not sure about your issue, but generally it is pretty damn close and mine has left some deep rub marks, i adjusted the derailleur and stopped using that cog
    Pivot mach 6!
    Jun 2010
    Quote Originally Posted by Joel RW View Post
    If that's the case I'm gonna sell this POS and get something else.
    Ok now that I've calmed down can anyone recommend a hub that offers more clearance? Does one exist?
    Jul 2013
    Mine does the same thing with I-9 hubs. I don't think it's a hub issue, I think it's a frame issue. Some sort of spacer between the frame and hub would probably fix it.
    Jun 2010
    Sure would be nice if that "Pivotal figure" would chime in.
    Reputation: vikb's Avatar
    Clearance on my M6 in the smallest XX1 cassette cog is minimal.
    I'm just going to stick a Lizard Skin patch on there and replace it every once in a while. It's not a gear I use frequently.
    Safe riding,
    Vik
    www.vikapproved.com
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Give me a call at the shop. Been slammed w Sea Otter preps and haven't had much time to keep up with other stuff.
    480-467-2920
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    There is a kit available from Pivot to solve the issue.
    Jun 2010
    Quote Originally Posted by Salespunk View Post
    Been super busy this past week haven't had time to call Pivot. Tell me more about this kit. Is it free? Or do I have to pay Pivot to make my bike work correctly?
    It is free. Looks like a washer that is bonded to the frame using some stuff they provide.
    Thanks. I'll look into getting one.
    Safe riding,
    Vik
    www.vikapproved.com
    Looks like this
    Little glue in pos
    Attached Thumbnails Attached Thumbnails Mach 6 plus Stan's hub plus XO cassete equals chain rub on inner seat stay-image.jpg
    Quote Originally Posted by acmack View Post
    Little glue in pos
    Is that from Pivot or some DIY work?
    Safe riding,
    Vik
    www.vikapproved.com
    From pivot
    From pivot
    Wow. That's a state of the art solution.
    Safe riding,
    Vik
    www.vikapproved.com
    Pivotal figure
    Jan 2003
    Official response:
    Actually, it is a state of the art solution that has been amended all at the factory production level and fortunately can also be added later on. The parts are precision CNC machined and fit the dropout perfectly. In an effort to design the Mach 6 with short chainstays, great stiffness and great heel clearance, this area was reduced to the minimum spec. However, with different hubs/cassette bodies having different tolerances, combined with variance in paint thickness and even tolerance differences in the chains, we have experienced this issue with certain combinations. In an effort to account for every combination in the market place, we made this small running change to the frame design. If you have a Mach 6 running SRAM 1 X 11 and have a clearance issue with your frame, we (Pivot) are taking care of this free of charge. You just need to contact Pivot or your local dealer and we will work with you to figure out the best way to handle the update.
    This is directly from Chris C.
    Perhaps it looks more state of the art in person. I'll see when I get mine.
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: k2rider1964's Avatar
    Having mine fixed at The Path next week. Pivot shipped the part today to complete the fix.
    It works good, once you glue it in its semi permenant, there is still heaps of lip in the dropout to catch the wheel axle. It's just a bit of a surprise before the fix when your new $$$$ 11 speed is actually a 10 speed!
    Quote Originally Posted by kenbentit View Post
    Official response:
    My Mach 6 with X01 build is experiencing the rubbing so I called Pivot yesterday and they said I HAD to bring the bike into a local dealer. The two closest dealers are an hour away which makes this a real pain in the ass to resolve. I'm pretty pissed off at Pivot right now...and it's really taking away the excitement I had from buying it in the first place.
    Thanks Pivot! (sarcasm)
    Jun 2010
    Mine turned into a 9 from a 10
    State of the art spacer. Glue into your drive side dropout and you are XX1/XO1 compatible!
    Safe riding,
    Vik
    www.vikapproved.com
    Jun 2010
    Official response:
    Do I need to go to Pivot directly? My LBS told me some woman at Pivot needed a pic of my dropout . Sent LBS a pic. Haven't heard anything in 2 weeks. Chris C. seems cool, are his employees?
    Pivotal figure
    Jan 2003
    The shop just needs to send us the pic but you can always contact us directly as well.
    Jun 2010
    Guess I'll have to contact you directly. My LBS is having no luck. It's been a month and they cannot resolve this issue.
    Quote Originally Posted by Ineedmorecowbell View Post
    The shim takes all of 30 seconds to glue into place. Mine came out during a wheel install and had to be re-glued. So it's a bit of a PITA, but when it's in place it works well.
    Safe riding,
    Vik
    www.vikapproved.com
    Pivotal figure
    Jan 2003
    Def. give us a call! That's way too long....
    Pivotal figure
    Jan 2003
    It's easy to install but you do need to let the epoxy cure for a min. of 4 hours before doing anything. Prepping the surface is also key, I'm betting installing these parts after the bike has been ridden will require a higher level of contaminant removal than what we deal with on a brand new frame.
    Quote Originally Posted by vikb View Post
    Reputation: Kronze667's Avatar
    Aug 2014
    My pivot mach 6 has about 2-3mm of space between the 11 tooth Cog/XTR 10 speed chain and the upper chain stay and the cassette is fitted to a Hope Evo Pro 2 Hub. Thing is it doesn't Rub (there is an upper chain stay protector on the mach 6) but maybe that's because I have my chain tensioned pretty well and my Gamut Chain Guide keeps the chain where it should be..most of the time
    Oh those chain stay protectors are not that great on the Pivot Mach6 or is that just because the glue holding them on is rubbish ? Hmmm the glue probably lol!
    Aug 2014
    Hmm, I zip tied my Pivot chain stay protector's because the glue that Pivot used is not wearing well at all..problem kinda solved...I hope
    Quote Originally Posted by Kronze667 View Post
    I found a flexible adhesive like Shoe Goo or Freesole works well for sticking those rubber protectors back on the frame.
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: SDMTB'er's Avatar
    Feb 2014
    Ditto shoo goo works great. Just hold the protector in place with a couple of wire ties while it is drying. Then once dry clip them off.
  1. Replies: 21
    Last Post: 08-26-2014, 07:24 AM
  2. Camber Q factor and Chain/seat stay clearance.
    By Stevebiker in forum Specialized
    Last Post: 03-27-2013, 05:47 PM
  3. Bad quality control on chain or cassete?
    By hapaknack in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-09-2012, 07:28 PM
  4. Fewer engagement points equals more chain slap?
    By dunerinaz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-16-2011, 07:03 PM
  5. replacing chain what if you dont change your cassete?
    By clj766 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-14-2011, 07:52 AM
