Results 1 to 6 of 6
    Reputation: scoutcat's Avatar
    mach 5 and xtr front derailleur
    is the latest shimano xtr direct mount front der (fd-m981) compatible with the mach 5? i think it is not but wanted to double check.
    Not just famous; infamous
    Reputation: coolhandluchs's Avatar
    I'm pretty sure only the E-type fits, but hopefully someone that knows more than me will chime in...
    the direct mount listed above is not compatible. you need to get the e-type and remove the backplate.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Yep, 981 is a clamp on style. You want the E-type and if you're getting the new DynaSys version make sure your chainring's are compatible (42t max ring size).
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Paterfamilias
    Feb 2006
    If you need a 9 speed triple XTR FD, use the model number FD-M970-E
    If you need a 10 speed triple XTR FD, use the model number FD-M80-E
    If you need a 10 speed double XTR FD (our frames only work with the 38T or 40T options), use the model number FD-M985-E2
    the FD is available without the E-Type plate, if you buy the FD with the plate, please remove it, and use the FD screws provided with our frames.
    I hope that helps!
    "The face of a child can say it all, especially the mouth part of the face".
    Jack Handy
    Quote Originally Posted by dan23
    I hope that helps!
    it does, i got hung up on "direct mount." some retailers dont understand that the backplate can be removed thus making it a "low direct mount."
    thanks!
