Results 1 to 5 of 5
Thread: Mach 5 weights?
    offroader
    Dec 2008
    Mach 5 weights?
    Post up your Mach 5 weights if you got em. I'd like to see how mine compares to the average bike.
    This is what I have so far
    Frame: Large 2009 Mach 5 29lbs +- .5lbs (w pedals)
    -Ardent 2.4 exo tires + performance tubes (could cut about .5 lbs with tubeless)
    -Stans Flow EX + Hope Evo 2 hubs + Sapim Race
    -X0 Long cage RD, Hone FD, X9 Shifters, KMC SL9 chain, pg990 cassette
    -XT m775 Cranks
    -XT m785 Brakes
    -Thomson X4 Stem/Thomson 360mm post
    -WTB Vigo Saddle
    -Truvativ Noir Carbon bar low rise
    -Odi lock grips
    -Eggbeater SL pedals
    26 pounds
    2008 Mach 5 medium
    Stan's Crest Wheelset with Racing Ralph front Maxis Aspen Rear tubeless
    Syntace P6 Hi Flex seat post with Selle Italian Flite saddle
    90 mm 15 degree stem with Ritchy WSC Carbon bars
    XO shifters and rear mech XT front mech
    XT cranks XTR pedals
    XT Brakes
    27.5 pounds with XT Wheelset and Schwalbe Hans Damph tyres.
    offroader
    Dec 2008
    Almost the same build.. wonder why mine is so much heavier?
    Quote Originally Posted by CupOfJava View Post
    You have a large frame mine is medium, this would be the main difference.
    Little things like grips maybe. Mine are ESI foam yours are lock on. ESI's are 50 grams a pair.
    Flite saddle it 220 grams WTB Vigo if it is the same as my original is around 270.
    The Stans Crest wheelset is 1420 grams and I am running light tyres tubeless.
    All the little things add up plus the frame and wheels so it makes a big difference in the end.
    If you are on a large frame you are probably over 6 foot tall so you have the strength to push it. In the end it is about fitness anyway the weight in general is not such a big factor.
    offroader
    Dec 2008
    Yep you're probably right (about fitness) although I'm not particularly a strong rider. Thanks for your input.
  1. Replies: 6
    Last Post: 10-13-2013, 10:04 AM
  2. Replies: 7
    Last Post: 02-18-2013, 11:44 PM
  3. XX1 Mini-Review & Weights, XTR Weights, Race Face Next Crank Weight
    By brentos in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-31-2012, 05:03 PM
  4. Hub weights...Syncros, wtb, Hope pro 2 Evo weights
    By RTM in forum Downhill - Freeride
    Last Post: 07-26-2012, 06:44 PM
  5. another sizing question Mach 5.7 vs mach 5.
    By snoroqc in forum Pivot Cycles
    Last Post: 01-11-2012, 01:43 PM
