Results 1 to 9 of 9
    Mach 5.7c rear skewer type?
    What type of rear skewer is compatible with the Mach 5.7c?
    Syntace x-12 type
    Shimano E-thru
    I think all that matters is the type of threading it has. I'm looking to replace mine with one of the tune skewers and there are apparently two different types and I'm wondering which to get.
    Mine came with a DT Swiss.
    Paterfamilias
    Feb 2006
    We use the DT Swiss RWS Axle, it has a custom thread to Match the Shimano threading pattern. Your dealer can order these from us, if you need one. Retail is around $45.
    "The face of a child can say it all, especially the mouth part of the face".
    Jack Handy
    Feb 2012
    Here it is on CRC
    It bolts directly into the derailleur hanger
    Paterfamilias
    Feb 2006
    As I mentioned above this post the DT RWS axle we use is custom for PIVOT. If you need a replacement your dealer can order one for you. The one sold a CRC will not work bit has the wrong thread.
    Quote Originally Posted by 11highlights View Post
    Here it is on CRC
    Jack Handy
    Quote Originally Posted by dan23 View Post
    There's no reason a shimano axle won't work is there?
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    It needs to be the correct thread pitch...
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Quote Originally Posted by kenbentit View Post
    Dan said it was the shimano thread pattern. So the shimano 142x12 skewer will work right?
    Paterfamilias
    Feb 2006
    Quote Originally Posted by litany View Post
    No, the head on the Shimano Skewer will not fit on our non-drive side with out shims, or washers. And even then, you may not have enough thread contact for it to work correctly.
    You can buy the DT Swiss RWS Axle from your dealer, and it comes with the frame.
    Jack Handy
  1. rear skewer
    By scribble79 in forum General Discussion
    Last Post: 09-04-2012, 11:13 AM
  2. Need a replacement rear (QR) skewer
    By MetaOrbit in forum Beginner's Corner
    Last Post: 08-28-2012, 07:49 AM
  3. Mach 5.7 upper bearing type
    By paddy73 in forum Pivot Cycles
    Last Post: 08-09-2012, 07:37 AM
  4. need a 142 rear light skewer
    By eliflap in forum Weight Weenies
    Last Post: 04-15-2011, 11:53 AM
  5. Rear hub/skewer
    By mtnbkr33 in forum Wheels and Tires
    Last Post: 04-12-2011, 11:54 AM
