Results 1 to 3 of 3
    Mar 2013
    Mach 5.7 carbon front shock ?
    So I ordered a 2013 mach 5.7 carbon frame small last month and it is do in this Easter weekend, so I can start my build. My question to all of you is I also ordered a fox 34 float to go with it, based off of other information I have gathered over the last 4 months from this forum. I had told my bike shop to lower it to 150mm but they were suggesting to keep it at 160 and ride it that way for a bit. Now he is charging me only 50 bucks to drop it and based on others here that is pretty cheap or on par. I just wanna ride the bike as it was meant to from Pivot. I also understand that the A2C still wont be the same as a 32 but it will be a lot closer then the 160. what is everyone elses thoughts on this. Stumped whether I should do it now or not.
    Mar 2013
    My bike is built and the snow is melting (despite the threat of more to come). I asked my Lbs to drop the 34 (which came in black yeah). My decision was based on this thread. mach 5.7 and 34 fork, specifically reply #19. Hope this helps. Good luck with the build.
    Reputation: JMW503's Avatar
    Quote Originally Posted by Spidey2422 View Post
    Lower it. I got the Talas 160 and it was fine on bomber downhills, techy rocks, longer flow trails (first few rides), but sucked on bermed hairpins, tighter switchbacks, etc. later rides. I went ahead and swapped out the air shaft lower assembly to a 120/150 and the ride has been fantastic ever since. The geo get's too screwed up with the extra 17mm A2C change, which sounds odd considering it's not that dramatic of a change, but makes sense since the bike was designed for a 140 mm or 150mm fork.
    Just lower it now and enjoy the bike to it's fullest.
  1. Mach 5.7 Carbon Front Derailleur Issue
    By Isildur in forum Pivot Cycles
    Last Post: 10-19-2012, 08:55 PM
  2. Rear Shock on a Mach 5.7
    By Tofu in forum Pivot Cycles
    Last Post: 03-31-2012, 09:38 AM
  3. Mach 5.7 carbon 3x9 front derailleur
    By PeterG in forum Pivot Cycles
    Last Post: 12-03-2011, 05:55 AM
  4. Mach 429 Rear Shock PSI?
    By nowshon in forum Pivot Cycles
    Last Post: 08-09-2011, 04:19 PM
  5. Mach 5 + Monarch Plus Shock
    By joshdurston in forum Pivot Cycles
    Last Post: 07-18-2011, 02:41 PM
