Results 1 to 5 of 5
    Jan 2011
    Mach 5.7 Alloy upper link maintenance
    Hi all,
    I think it is time for me to replace the suspension bearings on my 5.7 Alloy from 2011
    Yes; quite some kilometers, and 3 muddy winters...
    I can see on Pivot site a good PDF on how to do that for the lower DW-Link, but nothing equivalent to remove/install the 4 bearings of the carbon rocker upper link ...
    Anyone has got some litterature, or is this just so simple that no DIY manual/video is even needed?
    Thanks for support and shared experience
    Sep 2012
    Also interested.
    Reputation: -Chainslap-'s Avatar
    I don't know what pivot recommends but I just used my slide hammer/pilot bearing remover. Took about three minutes for all four. And I was able to just hold the links in my hand. Then I just used a brass drift to pop the new ones in. Alternatively, I bet you could use some all thread, sockets, and a couple nuts to push them out/in. Or a vice with soft jaws and a rag.
    I will say the slide hammer has been one of the best tools Ive purchased. I use it on all kinds of bearings.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    At the shop we have a fairly simple puller that's pretty much a bolt and socket setup. Tightening the bolt pulls the bearing into the socket and out of the rocker.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Jan 2011
    Thanks for advices guys!
    I don't have a slide hammer, but the 'bolt+socket' trick looks really smart; i'll give it a try
  1. Blur LTc Upper Link maintenance
    By brumos in forum Santa Cruz
    Last Post: 08-25-2014, 04:13 AM
  2. Mach 5.7 upper bearing type
    By paddy73 in forum Pivot Cycles
    Last Post: 08-09-2012, 07:37 AM
  3. squeaky upper link on SS2
    By wonny in forum Intense
    Last Post: 06-19-2012, 10:53 PM
  4. APP Upper link adjustment
    By Erotomania in forum Santa Cruz
    Last Post: 03-20-2012, 01:44 PM
  5. Spider 2 Upper link on XVP?
    By jrsbike in forum Intense
    Last Post: 08-23-2011, 09:30 AM
