Results 1 to 5 of 5
    Reputation: skiahh's Avatar
    Lunchbox link bearings?
    Just got my lunchbox today and started swapping parts. I don't have a crank cap removal tool (can the new link be installed without pulling the crank and front DR?) or any anti-seize, so I didn't get all that far installing it tonight.
    Maybe this is a dumb question, but can I pull the bearings from the original link and put them in the new (SL) link or does this new link need new bearings (and if so, why aren't they in the kit??)? Thanks!
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    The SL link uses a different bearing than the standard link. There are 4 double row bearings in it Vs 8 single row bearings in the standard. That's one way we saved weight on that link. The link is already assembled with new bearings so you don't have to put anything together. You do need to pull the cranks to install it though...
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Thanks, ken -
    I was getting started last night and I guess it was late because it just looked like there weren't any in there! I just checked again and lo and behold, there they are! lol Guess I shouldn't work on stuff like this late at night!
    Now to get the crankset off.
    Pivotal figure
    Jan 2003
    Oh man, I've learned the hard way not to start any bike project at night
    Well, got it all put together, except the headset which is on the way (the headset in the lunchbox is for a tapered HS, so my shop swapped it and it'll be here Tuesday). Love the look of the black and blue!!
