Results 1 to 5 of 5
Thread: lunchbox
    pyroclastic flow
    Reputation: troyer2112's Avatar
    lunchbox
    what would the real benefit of the lunchbox be? is it just a coloring thing or would the bearings be that much better?
    "THE FACT IS THIS FRICTION WILL ONLY BE WORN BY PERSISTENCE"
    2009 PIVOT MACH 4
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    It depends on which bike you have. The newer Mach 4's come with the SL Link which saves a bit of weight over the standard link that comes on the Mach5, 429 and 5.7. The Lunchbox kit has all the colored ano. parts and the matching SL link so you could drop a little weight as well as customizing your bike.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Reputation: intensworks's Avatar
    Mach 5.7 Lunchbox?
    Now that the Mach 5.7 went tapered, would the lunchbox now include both lower cups (inset 1 1/2 and inset 1 1/8?)
    Apr 2005
    Quote Originally Posted by intensworks
    My black lunchbox (for my 5.7) came with a tapered headset. Make sure you specify what frame you're putting it on when you order.
    Reputation: skiahh's Avatar
    Plus you get a King headset.
    Is it worth it? Probably not... but sometimes you gotta splurge!
    (I got the blue for my black 429 )
