Results 1 to 9 of 9
    Reputation: Cult Hero's Avatar
    Loose lower link on Pivot Mach 5.7 Carbon
    Servicing a friends Pivot the other day and the lower suspension link has some serious play in it. Before I pull it all apart are these user serviceable bearings, does pivot sell a replacement kit, or are there any aftermarket options that are superior?
    Pretty surprised really as he is a newer rider with less than 20 rides on the bike and the slop is very noticeable. Is this a common issue?
    May 2013
    I had my lower link + all bearings replaced on my carbon 5.7 after 7months,all replaced under warranty!
    Oh geez. Is that uncommon or a fluke? I have two friends with identical bikes and one is really sloppy one is seemingly fine.
    Mar 2013
    I am going to say uncommon but I only have about 20 rides on my 5.7C as well. I check my bike out every so often when I clean her and last check there was no play what so ever. I would call Pivot or go back to the dealer your friend bought the bike from and see if they can't set you up with a new set of bearings.
    May 2013
    I hope a fluke,most rides are muddy & wet,i live in the Lakes UK.Play never felt to bad only when I stood up on the climbs!
    Guess this is something that is a little more common
    Lateral Flex on my 5.7c
    I have replaced my lower link bearings twice on my 2011 5.7 aluminum. I check the pivot bolts often to make sure they are torqued properly.
    Feb 2010
    I have had to replace the dw-link bearings the last two springs after riding in wet and muddy conditions all winter. There was only a little play in the lower link, lots of creaking though. Pivot hooked me up with the wider bearings this time.
    That is exactly what it was. We took it apart and the bearings had completely disintegrated. Completely gone. Dust. Ha ha. He called pivot and was told that their bearing manufacturer had changed specs halfway through the product run and not told them. Said to send back back the lower link and they old take care of it.
    Cool.
  1. New Pivot Mach 429 Carbon with XX1...
    By Green Giant in forum 29er Bikes
    Last Post: 12-25-2014, 10:00 PM
  2. Help me spec out my Pivot Mach 5.7 Carbon
    By litany in forum Weight Weenies
    Last Post: 08-05-2013, 11:37 AM
  3. Lower pivot bolts keep coming loose!!!
    By pulpwoody in forum Marin
    Last Post: 07-30-2012, 05:52 AM
  4. Replies: 1
    Last Post: 05-21-2012, 06:37 PM
  5. 2011 SJ Carbon Pivot Loose
    By snow-man in forum Specialized
    Last Post: 02-21-2012, 02:06 PM
