Results 1 to 9 of 9
    Aug 2010
    Les 29 & Rohloff
    Anyone tried the above? What axle plate (I assume the OEM one won't work)?
    Reputation: vikb's Avatar
    I've got a couple Rohloffs and didn't think they were through axle compatible.
    Safe riding,
    Vik
    www.vikapproved.com
    Aug 2010
    Quote Originally Posted by vikb View Post
    They aren't, but the swinger dropouts on the Les 29 aren't either.
    Quote Originally Posted by ratherbeintobago View Post
    Got it. I assumed they were 142 through axle.
    If they are QR 135 you can use a Monkey Bone disc brake adapter [only in 160mm I think] and an OEM 2 axle plate for a clean setup.
    Rohloff w/ Monkey Bone on my Surly Krampus.
    Safe riding,
    Vik
    www.vikapproved.com
    Aug 2010
    The rear brake is postmount.
    Ok. Then I am out of options. Sorry.
    Safe riding,
    Vik
    www.vikapproved.com
    Dec 2005
    If you're handy, you could fabricate something like this:
    Found it while doing a similar search.
    Sorry to highjack this thread, but Vik, do you have any problems mounting your wheel with this setup?
    I have the threaded axle version, with the OEM2 axle plate and Monkey Bone, and can't seem to feed the plate into the Monkey Bone while mounting the wheel onto my Krampus (the axle won't clear the bottom part of the drops in order to slide into place).
    Do you have to remove the Monkey Bone from the frame each time you remove the wheel? Or have I been staring at my bike for too long and am missing something very obvious?
    Quote Originally Posted by namelessontrail View Post
    I've had my Krampus' rear wheel off exactly once in over a year of ownership so I'm trying to recall what I needed to do.
    I think I just loosened the bolts holding the Monkey Bone so it could slide and that gave me the wiggle room to pull and re-insert the wheel.
    I'm going to pull my wheel to set it up tubeless and I'll post a note here with the process required.
    What I do remember when I had to fix a flat trailside last summer was that it was no big deal. If it normally takes 5mins to fix a flat this setup takes 6 mins.
    Nothing I worry about.
    Safe riding,
    Vik
    www.vikapproved.com
  1. Rohloff 142 x 12
    By TraxFactory in forum Internal Gear Hubs
    Last Post: 11-17-2015, 07:41 AM
  2. New Rohloff rig
    By Midle Age Warrior in forum Internal Gear Hubs
    Last Post: 06-27-2014, 05:45 PM
  3. Sultan and Rohloff ?
    By TraxFactory in forum Turner
    Last Post: 06-17-2014, 01:27 PM
  4. Rohloff/Ogre
    By rjcarlson49 in forum Internal Gear Hubs
    Last Post: 03-29-2013, 07:49 AM
  5. 13 speed Rohloff
    By JanBoothius in forum Internal Gear Hubs
    Last Post: 12-02-2011, 07:30 AM
