Results 1 to 16 of 16
    May 2013
    Hive XCX e-type chain guide on Mach 5?
    Has anyone used this on their Mach 5 or any other Pivot? I curious if it fits. Thanks
    XCX+ E-type/S3 Direct Mount | the hive
    Dec 2009
    XCX+ High Direct Mount | the hive
    I use this and it works great.
    May 2013
    ah so the high direct mount works. Do you have pictures? Thanks
    Dec 2009
    No pics at this time. Sorry
    May 2013
    Does anyone know if the low mount works also?
    Dec 2009
    Low mount guides will not work on high mount frames
    May 2013
    Quote Originally Posted by gunt pimp View Post
    Ok thanks again. Which frame do you have?
    Just put one on, E-type/s3 direct mount. The MRP one, 1x i think, didn't work for the 34t ring I was trying to run since there's a nut on the otherside of the guide. Chain was hitting on the sides of the guide.
    Mach 5.
    May 2013
    Thanks for the pic! Is that a high mount or a low mount? Looks like a low mount..
    Low mount.
    Nov 2012
    Quote Originally Posted by nuutsak View Post
    Low mount.
    Hi, does anyone know, if the e13 XCX+ high mount works with a 30t guidering e.g. wolftooth?
    I would also be very grateful for any other suggestions for a high mount chain guide working with a single 30t guidering.
    Reputation: RS VR6's Avatar
    Looking into this option as well. Went 1x and used a Raceface 30T ring. I got a Bionicon and the chain drops when I'm in the 11T.
    Aug 2010
    I use a 30t NW Race Face, don't need a chain guide at all...not 1 drop since buying it 4 months ago. 1x10 M6
    I'm using a 9sp XT...no clutch.
    Nov 2012
    I've seen that one. Shiftup also has one...and the price is similar.
    direct mount Chain catcher
    It could be made cheaper by using plastic instead of carbon.
  1. Help with identifying which chain guide/bb type
    By Fc_misc in forum Downhill - Freeride
    Last Post: 02-03-2013, 02:07 PM
  2. E13 e-type chain guide - finally! (maybe)
    By 92gli in forum Pivot Cycles
    Last Post: 01-26-2012, 07:42 PM
  3. 1x9/10 chain guide on Mach 4 if you are curious...
    By madsedan in forum Pivot Cycles
    Last Post: 07-19-2011, 07:42 AM
  4. Where can I get e*thirteen xcx e-type chain guide?
    By madsedan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-09-2011, 09:46 AM
  5. MotoLite Hive cranks, what chain guide?
    By banks in forum Titus
    Last Post: 03-06-2011, 06:57 PM
