• 06-26-2013
    Lemonaid
    Hive XCX e-type chain guide on Mach 5?
    Has anyone used this on their Mach 5 or any other Pivot? I curious if it fits. Thanks
    XCX+ E-type/S3 Direct Mount | the hive
  • 06-26-2013
    gunt pimp
    XCX+ High Direct Mount | the hive
    I use this and it works great.
  • 06-28-2013
    Lemonaid
    ah so the high direct mount works. Do you have pictures? Thanks
  • 06-28-2013
    gunt pimp
    No pics at this time. Sorry
  • 06-28-2013
    Lemonaid
    Does anyone know if the low mount works also?
  • 06-28-2013
    gunt pimp
    Low mount guides will not work on high mount frames
  • 06-28-2013
    Lemonaid
    Ok thanks again. Which frame do you have?
  • 06-28-2013
    nuutsak
    Attachment 811955
    Just put one on, E-type/s3 direct mount. The MRP one, 1x i think, didn't work for the 34t ring I was trying to run since there's a nut on the otherside of the guide. Chain was hitting on the sides of the guide.
    Mach 5.
  • 07-01-2013
    Lemonaid
    Thanks for the pic! Is that a high mount or a low mount? Looks like a low mount..
  • 07-01-2013
    nuutsak
    Low mount.
  • 05-27-2014
    trailinger
    Originally Posted by nuutsak View Post
    Low mount.
    Hi, does anyone know, if the e13 XCX+ high mount works with a 30t guidering e.g. wolftooth?
    I would also be very grateful for any other suggestions for a high mount chain guide working with a single 30t guidering.
  • 05-27-2014
    RS VR6
    Looking into this option as well. Went 1x and used a Raceface 30T ring. I got a Bionicon and the chain drops when I'm in the 11T.
  • 05-27-2014
    pedal-man
    I use a 30t NW Race Face, don't need a chain guide at all...not 1 drop since buying it 4 months ago. 1x10 M6
  • 05-27-2014
    RS VR6
    I'm using a 9sp XT...no clutch.
  • 05-28-2014
    trailinger
  • 05-28-2014
    RS VR6
    I've seen that one. Shiftup also has one...and the price is similar.
    direct mount Chain catcher
    It could be made cheaper by using plastic instead of carbon.
