Results 1 to 11 of 11
    help mach 4 Bottom bracket
    I just purchased a 2010 mach 4 frame. My exsisting xt crank will not fit? the spindle will only slide on the drive side and will not fit through the left side of bb. please help?
    more info
    On the non drive side of bb there is a silver ring that is the same diameter as the spindle on my xt crankset. Am i using the wrong crankset?
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Can you post a pic of the BB? The XTR BB we spec on the bike doesn't have any metal ring, it's a composite material.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    gxp bottom bracket
    I figured out that it is a GXP bottom bracket.
    Pivotal figure
    Jan 2003
    Oh yeah, that would cause a problem
    Pivot Mach 4
    Thanks for your help. Here is a Pic.
    Pivotal figure
    Jan 2003
    NIce! Is that an inverted fork?
    Yes, a Maverick SC32. It is pretty light at 3-1/2 lbs.It's axle to crown is close to a Fox 120.
    Quote Originally Posted by regulator3212
    If its just a metal ring, you may be able to press it out. I know the Enduro BBs for GXP are just the same as the Shimano BBs, but with that shim added to fit GXP.
    Truvativ
    Interesting, I do like running Shimano cranks. I using a cheap Truvativ for the meantime. Would you suggest this tool?
    http://www.parktool.com/product/pres...aring-tool-set
    I'd recommend getting a proper BB
    I've never done it myself, so no idea on the tool. The tool you linked is for the entire bearing though, and you only need to press out the little metal insert.
