Results 1 to 6 of 6
Thread: headset options
    more beers, lees gears.
    Reputation: mattKHS's Avatar
    headset options
    Just picked up a Pivot mach 4 frame and I need a headset. Seems like there really is not a lot of options.
    I have a Fox fork with the 40mm crown that tapers to the standard 30mm top .
    Is this the only headset option?
    Ritchey Zero WCS Carbon Headsets > Components > Headsets and Spacers > Headsets | Jenson USA Online Bike Shop
    I have been all over the usual bike sites and anything that is the 44mm insertion zero stack, has a 30mm crown.
    Just want to see a few options, but feeling pretty limited.
    A burrito is a sleeping bag for ground beef.
    MTBR Member
    Reputation: ncfisherman's Avatar
    From Pivot: "What headset do I need for my Pivot Cycles frame?
    For 2008 to 2010 Mach 4 and Mach 5, and 2008 to 2011 Mach 429 use a 44mm ID headtube designed to fit a zero-stack headset. ZS headsets press in just like a standard headset, but the entire headset, bearings and all, fit inside the headtube. The zero stack headset is designed to use a 1.125 standard steerer tube.
    For riders wanting to run a tapered steerer on 2008 to 2010 Mach 4 and Mach 5, and 2008 to 2011 Mach 429, we recommend a Cane Creek 40 TR44/40 lower headset cup. This is an external cup that allows the use of a tapered steerer for any of the above models
    So, you would just use a tradition external lower cup.
    You don't want that Ritchey headset...1) it doesn't accommodate tapered steerers 2) those look like drop in bearing, not press in cups
    The CaneCreek 44/40: Cane Creek 40 Series EC44/40 Bottom Cup > Components > Headsets and Spacers > Headsets | Jenson USA Online Bike Shop
    MTBR Member
    That's the one. Enjoy the bike.
    Fantastic. Thanks. I think it was my tapered steerer that was making this harder than it should have been, in my head at least.
    650b me
    Reputation: golden boy's Avatar
    I'm pretty sure Chris King makes one that will fit too, if you're looking to spend more money.
