Results 1 to 6 of 6
    Mar 2012
    Has anyone tried a 51mm offset fork on a 429a or 429c?
    Finally planning on replacing the aging TALAS with a 120mm Pike or similar. Should I be looking at 51mm offset or go with the standard 46mm? Anyone with experience with 51mm on a 429?
    Dec 2013
    Re: Has anyone tried a 51mm offset fork on a 429a or 429c?
    Quote Originally Posted by tadmcmichael View Post
    What's the offset on the 120 fox that ships on the 429c?
    The Czar is similar geometry to the 429c (just a tad more slack head angle) and David Turner has posted here that for the Czar he recommends 51mm on a 120 fork. For a 100 fork it depends what you prefer. Not specific to the 429 but still interesting reading.
    Czar Fork
    120mm on Turner Czar?
    Mar 2012
    Good info Matt, thanks.
    11 is one louder than 10
    Reputation: Green Giant's Avatar
    Been torn on this one myself on a 429c.
    It's designed around a 44mm offset Fox. The 34mm stanchions on the x-fusion trace tempt me, particularly at that weight.
    But, don't want to mess too much with the handling.
    "The thing is, Bob, it's not that I'm lazy, it's that I just don't care."
    Reputation: mtbnutty's Avatar
    Hey G. Giant,
    Do you know if the 429 aluminum is designed around the Fox 44mm offset also? A kid in the bike store said it was designed around a 46mm.
    Mar 2012
    mtbnutty,
    The 429a was designed with the 44 mm spec Fox. That said, I don't know if you could tell the difference between the 44 and 46 mm offset. People do notice the difference between the 46 mm and 51 mm, but many say that the difference is not significant. Also, the quick handling at slow speed with the longer offset does have some trade offs in higher speed stability. I just can't find much about how the 51 offset on the 429.
  1. 51mm offset Fork on a Tallboy?
    By bikerbrad in forum Santa Cruz
    Last Post: 12-22-2013, 07:34 AM
  2. where to buy Fox 51mm offset fork?
    By Motivated in forum Shocks and Suspension
    Last Post: 09-13-2013, 08:21 AM
  3. Replies: 65
    Last Post: 05-23-2013, 02:16 PM
  4. 51mm/Fisher offset Fox fork on a Vassago?
    By SteveF in forum 29er Bikes
    Last Post: 12-22-2011, 11:16 PM
  5. Fork Offset for Air9, 46 vs 51mm
    By UtahSpines in forum Niner Bikes
    Last Post: 03-26-2011, 05:09 AM
