Results 1 to 6 of 6
    Front Derailleur on Mach 4
    Hi All,
    I just picked up my new 2013 mach 4 frame and trying to install the front derailleur. I searched through the Pivot threads and folks are saying to just bolt the derailleur to the frame without any spacers. If I do this... the front derailleur cage hits the rear tire. Is that normal or does the limit screws prevent this from happening? I havent installed the cable for the front derailleur yet. Just wanted to make sure I dont need any special spacer. My front derailleur is XTR M970E. Thanks in advance.
    Or am I not suppose to screw the left screw/bolt all the way down? And that left screw/bolt is to fine tune the angle of the cage...
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    You do want both of the screws completely tight, there's no angle adjustment on that der. I've never had one hit the rear tire even before adjusting the limit screws. Did your der. come with the BB mount bracket and did you remove all of that hardware? You just want the bare der. body when you bolt it to the frame... Pictures are great too. Hope this helps, otherwise just give us a call.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Hi Kenbentit,
    Thanks for the reply!
    Here are some pictures. its actually really hard to take a picture at that angle. Hopefully you can make it out. The bike is upside down. My derailleur came without the bb mount. Am I suppose to take the silver part off too?
    Front Derailleur on Mach 4-p1000142.jpgFront Derailleur on Mach 4-p1000148.jpg
    Okay looks like if I pop off that silver looking part and push the derailleur with a little bit more pressure than I did initially... it goes flush with the frame without hitting the tire. My derail came with the silver looking part attached so I figured that it suppose to be on there and it was pretty hard to pop off initially. Thanks for the help!
    Yep I know my bb is not pressed all the way in .
    Pivotal figure
    Jan 2003
    Yep! You got it figured out. That silver piece is what you'd use to attach the BB mounting bracket. I kinda figured it might be the culprit
  1. Mach 5.7 Carbon Front Derailleur Issue
    By Isildur in forum Pivot Cycles
    Last Post: 10-19-2012, 08:55 PM
  2. FR derailleur question for Mach 5.7
    By Mutt in forum Pivot Cycles
    Last Post: 12-22-2011, 01:11 PM
  3. Mach 5.7 carbon 3x9 front derailleur
    By PeterG in forum Pivot Cycles
    Last Post: 12-03-2011, 05:55 AM
  4. Adapter for SRAM XX Front Derailleur on Mach 429
    By thorpedo in forum Pivot Cycles
    Last Post: 08-15-2011, 10:12 AM
  5. mach 5 and xtr front derailleur
    By scoutcat in forum Pivot Cycles
    Last Post: 03-09-2011, 03:45 PM
