Results 1 to 6 of 6
    Fox 34 on a 429C?
    Hey everyone, is it possible to get a Fox 34 120mm Fork? If so, how would one go about getting one?
    change is good
    Sep 2004
    Fox 34 on a 429C?
    When I contacted Fox a year ago I was told the first generation could be lowered only to 130. The second generation's minimum travel was 140. I don't know what the current generation's minimal travel is. I have a SuperMax on mine and it rocks. I have a Pike on my 27.5 and it is a fine fork and the 29er version can go as low as 120. The Trace can be adjusted to as low as 100 I believe and has received great reviews.
    change is good
    Sep 2004
    Fox 34 on a 429C?
    Search Green Giant - he has excellent posts regarding large stanchion forks.
    Thanks, I appreciate the feedback. I'm just looking to get a little bit more stiffness out of my fork.
    Paterfamilias
    Feb 2006
    I had a FOX 34 130 on my Mach 429 Carbon, I just ran my sag a little lower to keep the head tube lower so the bike wouldn't wander on climbs. I loved it. My rider weight is around 235, and the 34 is so much stiffer, I loved it!
    "The face of a child can say it all, especially the mouth part of the face".
    Jack Handy
    11 is one louder than 10
    Reputation: Green Giant's Avatar
    So as much as I'd really like to go with a larger stanchion fork (especially after my fox 32 went it for it's third creaky crown) I haven't yet.
    Best two options from a handling standpoint seem to be.
    1. Pike and have someone mill down the rod 10mm (the 120mm rod). With the 46mm offset it should handle just like a 120mm fox.
    2. X-Fusion Trace. Crown to axles are nice on the 120mm. 51mm offset might lighten up the steering. I keep thinking one day I'm going to try one.
    "The thing is, Bob, it's not that I'm lazy, it's that I just don't care."
  1. 429 v 429c
    By etanc in forum Pivot Cycles
    Last Post: 12-09-2013, 09:42 PM
  2. 429c sag
    By krandrus in forum Pivot Cycles
    Last Post: 06-19-2013, 10:44 PM
  3. FD for 429C
    By ppcontrol in forum Pivot Cycles
    Last Post: 04-08-2013, 01:26 PM
  4. 429c vs Jet 9 RDO
    By Shmack in forum Pivot Cycles
    Last Post: 03-18-2013, 09:07 AM
  5. 429C at Interbike?
    By DLd in forum Pivot Cycles
    Last Post: 09-26-2012, 11:27 AM
