Results 1 to 7 of 7
    Dec 2004
    firebird upgrades for dh
    Have any of you upgraded your firebird to make it more dh friendly? If so what have you done?
    I have mine set up for am riding at about 32 lbs with the fox air and lyric air up front. I took it downhilling and was actually impressed with it. After getting busy with life I forgot how much I love downhilling, I am hooked again. Now I am debating whether to build up a cheaper dh bike or throw some dh parts onto the bird. I would only need a frame and fork for a dh rig. For the bird, I know I can go coil with the aluminum rocker and maybe an angleset. Is there anything else? Dual crown or is that a no no?
    Big Test Icycles
    Reputation: Hangtime's Avatar
    I have mine set up similar to yours. I too am planning on adding parts to the bird to make it more DH friendly. My short list is a spair wheel set. I dont want to drop big bucks so I'm looking at Transitions 32 and some heavier tires and a coil shock. This stuff can be had on MTBR or Pinkbike for decent prices. I have also wondered about the dual crown forks. I would opt for a Fox 180 for over a dual crown fork to save some weight, you would still get DH performance out of it.
    Dec 2011
    If you are looking at doing DH only, I'd upgrade the frame and forks. The firebird is a very capable bike, but it still is a trail bike and not designed for the rigors of serious DH (depending on trails?).
    Rear shock upgrade to a coil is the best upgrade I have seen people make, the RC4 on mine give a very plush ride. Add some decent brakes, dual ply tires, 50mm stem, wide bars... thats pretty much all it takes.
    I have compared the firebird against the phoenix, the the firebird struggles in fast steep rough sections, when the phoenix floats through these sections. I think slackening the head angle would help a lot in this regard, but it would be a bit of a pig on normal trails.
    Dec 2004
    I think the rough super steep rock gardens is really the only spot where the bike bothered me. I think I am going to upgrade from the 11 xt brakes to the 2012 version, and try it out with a fox coil in the rear. I read somewhere that guys were using anglesets but I have not seemed to find it yet.
    Proud Thunderchicken ownr
    Reputation: btibben's Avatar
    I'm still riding my 'bird in trail formation and just came back from a weekend of DH at Silver Star in BC. In the roots and rocks it was moderately out gunned as compared to a Norco Aurum I demo'd, but on the flow I could not be touched.
    Large 'bird w/ 160lb rider (naked)
    DHX 5.0 Air @ 170lb boost with a skosh more than 2 turns on the B.O.
    Totem Coil w/ flood gate removed
    Saint brakes
    I demo'd an Aurum because my fork started bleeding at the end of day 1. It made me love my bird even more.
    Common sense is not so common - Voltaire
    Never underestimate your own ignorance - Me
    Not sure if you have made your changes but I ride my bird pretty much as a DH bike. I bumped up my wheel set to the Sun ADD Pro. Super nice. I also got my RP23 Pushed. Push has a DH set up for the RP23. It made an amazing difference and helped manage those rocks. If you have not made any changes maybe try PUSH before spending a grip.
    I am also running the Fox 36 180. Love it.
    Reputation: rideflatout's Avatar
    man it's been a while since i've been on mtbr... I ride in the very rocky terrain of AZ/NV so even trail rides can have some harsh terrain. As I've owned it and ridden it for the past 3 years, I've made the following changes to suite what I like to ride and how I ride:
    -DHX coil rear shock
    -Outlaw wheels
    -DH casing 2.7 minion DHF and DH Ardent 2.6 on the back
    -FUNN Wider-than-stock- bars, I cant remember the width.
    -Animal flats pedals.
    -KS dropper post
    -SLX 2 ring cranks
    -Shimano shadow med cage rear der
    -Original fox 160 fork - a 170 might be in my future.
    I think of it like this: The whole reason I climb anything it to get to the DH part so I will gladly sacrifice some weight if it means more durability.
    FB VS tru DH bike:
    It CAN take more work and feel scarier on the rougher stuff than a purpose made DH bike, but it's OK cause I just pedaled my way up there. I also try to keep in mind is the margin for error is less. I can go hit a step-down gap (say, 6ft drop, 20 feet out), and the bike takes it completely fine. In fact I love how this bike handles in the air. If, however, I case that gap, I suspect there might be problems. and if I do that kind of thing over and over, I would not expect it to last.
    So to summarize, I consider my FB a trail bike with DH tendencies. It handles the rough, and will go as fast as I can get the guts up enough to go. It's heavy when you pick i up, but it rides way lighter than it feels. in an ideal world, I would prob own a 575 and a Phoenix, but the FB is like the best of both worlds, and I don't have to ever say, aw man, I wish I had my OTHER bike haha.
