Results 1 to 3 of 3
    Jan 2011
    Firebird - RC4 Mounting - Resivoir up or down?
    Hello Guys,
    After riding the RP23 for a nearly a season now, and yeah, the mid stroke blows through more than i like, i am ready to mount my 2012 RC4....
    i weigh with my gear around 185lbs and have a 400lb spring, so hopefully i will not need a softer/harder spring (fingers crossed) but they are not too much to get another though eh..
    ANYWAYS, i am wondering if i should mount the shock with the reservoir so it is at the top position or flip it around and have it mounted low.
    Seen photos from others mounted both ways...
    I would imagine it would be easier to adjust/control with it mounted at the top, and any rain/mud would not settle on the shock body as if it were mounted so the resivoir is low.
    Any thoughts or concerns?
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Mount it with the reservoir up and it'll be fine. I'm thinking the #400 spring is gonna be a bit firm for you but it'll be pretty close depending on how much stuff you carry in your pack. I run a #350 on my Phoenix and that's pretty much dead on for me (same body weight). I also run the Boost at 170 psi and 50% volume (2 turns in). The Boost will really change how the bike rides so I recommend experimenting with it to get a feel for where you want your settings. + or -10 psi in the Boost chamber will make a noticeable change so it's important to note how it rides at different settings and adjust accordingly.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Dec 2011
    I run #500 on the firebird and #450 of the phoenix - 45lb heavier than you guys, it's all muscle *cough*, seems to me it'll be in the ballpark.
    With it mounted up - reservoir at top, everything is easy to adjust on bike, never tried it upside down. Lower centre of mass - by the tiniest of margins?
    Most importantly let us know how it rides, coil is the best upgrade I have done.
