Results 1 to 7 of 7
    187 is offline
    Firebird MRP Specific Guide
    I having an issue and would like some feedback please. When I bought my firebird it came with the floating front shifter removed. I recently installed it but am having issues with the chain riding properly on the chainguide roller. You can see from the pics that the chain isn't going all the way up onto the inside of the roller. What could be causing this? I thought maybe a spacer needed added to set the roller farther outboard but the chain seems to lay perfectly on the rolller when the chain is on the larger chainring. What do you think?
    Firebird MRP Specific Guide-dsc_0691.jpgFirebird MRP Specific Guide-dsc_0694.jpgFirebird MRP Specific Guide-dsc_0673.jpg
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    I've found it helps to add a spacer behind the wheel but the thickness needed can vary. I normally try a .075" thickness, usually 1 thick and 1 thin washer and see how that works. If you can get ahold of some of the super thin shims that Magura or Hope use on their disc brakes it's easier to dial it in precisely. The fore/aft position of the wheel also affects the smoothness a bit but not as much as the side to side. It's surprising just how little variation in spacing will change the operation. I've had it work smoothly at one spacing then not work with just a .001" spacer added or removed.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    187 is offline
    Thanks. I'll try to space it out and see what happens. Have you seen a worn chain contribute to the problem?
    Pivotal figure
    Jan 2003
    Not really. It's just a factor of how much side to side angle there is since the chain needs to ride back up the guide wheel. I could see a badly worn chain being a bit more floppy but I don't know that it would be enough to make it not want to move up the wheel. I guess it is possible though....
    PMarsh Thumbs Up!
    Reputation: StuLax18's Avatar
    I hate this guide. I cut mine up after getting sick of it rubbing on the smaller ring, but now it falls off the big ring if I backpedal since the roller is no longer "pulling" it on. Mine never rode up onto the taller part of the roller, and after seeing how much damage my larger ring was taking and breaking off a tooth I went ahead with the modification.
    2011 Giant Glory 01
    2013 Pivot Firebird
    2004 Turner Rail - Stoled
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    Quote Originally Posted by StuLax18 View Post
    Sorry you had issues. I'm not sure how you lost a tooth with the bashring installed?
    NOAH SEARS
    MRP - Brand Manager
    Pivot Cycles - Team Rider
    PMarsh Thumbs Up!
    Quote Originally Posted by NoahColorado View Post
    Nevermind the bashring, it happened right where the crank is! Just a crazy situation. The only thing I can think is that the wear on the ring lead to it being weaker, and something got caught in the chain or a misshift.
    I'm interested in trying out other designs for 2x10 to see if they are better, because I get the idea this one works, but it takes some tweaking to get it perfect.
    2011 Giant Glory 01
    2013 Pivot Firebird
  1. Bionicon C.Guide V.02 Chain Guide + Fuel EX 8?
    By DBackRider08 in forum Trek
    Last Post: 09-23-2013, 04:03 PM
  2. Proper chain guide/end guide for Kona HeiHei 100
    By texasdirt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-09-2013, 08:10 AM
  3. Who on their 1xn drive has experimented with top guide+bionicon c.guide+clutch mech?
    By DeanFBM in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-11-2013, 12:51 PM
  4. Firebird-specific MRP LRP Installed
    By Rockweasel in forum Pivot Cycles
    Last Post: 02-08-2013, 01:03 PM
  5. Replies: 10
    Last Post: 03-08-2011, 04:06 AM
