Results 1 to 9 of 9
    Feb 2012
    Firebird DW link issues
    Out riding tonight and next thing i know the rear triangle was swaying all over the place. Haven't pulled it apart yet but visually I cant find anything broken?
    This happen to anyone else?
    #THELEGEND
    Reputation: Guy.Ford's Avatar
    Aside from making sure the bolt that hold the links are tight (doubt they'd be loose, but worth a check), I would suggest checking your wheel, be sure there are no loose spokes or the hub hasn't developed any play. GL
    #THELEGEND
    2016 RSD Mayor
    2018 Diamondback Release 5C
    2017 Diamondback Haanjo Trail
    Proud Thunderchicken ownr
    Reputation: btibben's Avatar
    Rocker bolts fall out? I guess the triangle could flex if the upper bolts came out and the lower DW link was still firm.
    Or maybe you sheered the rocker in half.
    Common sense is not so common - Voltaire
    Never underestimate your own ignorance - Me
    dog
    dog is offline
    sit! stay!
    Reputation: dog's Avatar
    like the others said... i broke a main pivot bolt once (big gold ones) and everything looked fine until I went to back them out and sure enough one of them had sheared in two...
    i need to develop my crashing skills...
    have felt the same strange sensation of the bike swaying or the feeling that something is not right. had a check on the bolts of the rocker...a couple were loose. This is not the first time it has happened. I also had one bolt broken before....its strange considering I don't do big jumps.
    I have to add that when I brought it to my LBS..they quickly fixed the problem (i.e change of bolts)
    Paterfamilias
    Feb 2006
    Regular maintenance of the frame, and checking the torsion on your bolts is something you should do often. It's always important to insure you are tightening bolts to the correct settings. Over tightening of bolts can create issues, and it can even cause bolts to loosen up. So, please be aware of these settings, as well as what type of grease, anti-seize, or thread compound to use for each bolt.
    http://www.pivotcycles.com//up/file/...orqueSpecs.pdf
    "The face of a child can say it all, especially the mouth part of the face".
    Jack Handy
    Feb 2012
    Quote Originally Posted by dan23 View Post
    Ended up being a warranty issue. Actually sheared the link pin in half, right where the threads met the shank. Pivot said it was only the 3rd time its ever happened. They shipped me new link pins and all new bearings at no cost.
    dog
    dog is offline
    sit! stay!
    then I wonder if mine was the first or second time?
    Ha, I think mine was mid 2010. Does that make me first or second?
  1. firebird DHX issues
    By le_buzz in forum Pivot Cycles
    Last Post: 09-16-2012, 08:04 AM
  2. Replies: 3
    Last Post: 08-01-2012, 03:55 AM
  3. Replies: 1
    Last Post: 07-09-2011, 04:34 AM
  4. HALF link link needed ,using 9spd sram geared chain
    By zippy895 in forum Singlespeed
    Last Post: 02-05-2011, 08:25 PM
  5. mini i-link vs. regular i-link
    By mtnbikecrazy55 in forum Weight Weenies
    Last Post: 01-19-2011, 01:29 PM
