Results 1 to 6 of 6
Thread: FD for 429C
    FD for 429C
    Just got the 429C but can't figure out which FD to use, no answer from Pivot in the last two days and may be you can help, thanks!
    For the Shimano XT group, should I use:
    -XT M780 E-type 3x10, or
    -XT M781 Direct Mount 3x10 ??
    Thanks guys!
    Apr 2005
    Direct mount.
    Quote Originally Posted by swinkey View Post
    Direct mount.
    Thank you, swinkey !
    Climber
    Jan 2013
    This is from Pivot's tech FAQs @ Tech Info | Pivot Cycles - Mountain Bikes for XC, Trail, Downhill
    Do I need a special front derailleur?
    Pivot uses e-type Shimano front derailleurs that are readily available from any shop or parts distributor. We simply unbolt the derailleur from the plate and mount them directly to the precision machined tabs on our frame. This gives all Pivot frames the perfect derailleur height, angle, and location, and a super rigid mounting surface for the most precise and positive front shifting possible.
    Apr 2005
    E-type is for the aluminum frames. The 429c need a direct mount.
    Climber
    Jan 2013
    Thanks, good to know as I have a 429c
  1. 429c carbon thread
    By insighter in forum Pivot Cycles
    Last Post: 02-19-2017, 02:18 PM
  2. Pivot 429c vs Niner Jet 9 RDO
    By Shmack in forum 29er Bikes
    Last Post: 01-29-2014, 09:31 AM
  3. 429c vs Jet 9 RDO
    By Shmack in forum Pivot Cycles
    Last Post: 03-18-2013, 09:07 AM
  4. ripley vs mach 429C vs tallboy vs other
    By mtbpri in forum Ibis
    Last Post: 11-11-2012, 06:56 AM
  5. 429C at Interbike?
    By DLd in forum Pivot Cycles
    Last Post: 09-26-2012, 11:27 AM
