Results 1 to 10 of 10
    dog
    dog is offline
    sit! stay!
    Reputation: dog's Avatar
    FB gets a new fork...
    Fox Float 36 180 RC2... yes i shimmed it to 170 mm if anyone from Pivot is taking notes...
    of course i figured it'd be better to include an action picture...
    i would title this one... "aerial view of cattle dog" or "why gticlay did not get a cattle dog"
    i need to develop my crashing skills...
    Mar 2006
    Sweet treehouse!
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Yer doggie is TINY!
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    #THELEGEND
    Reputation: Guy.Ford's Avatar
    Did you also mod the air chamber? Sweet ride btw congrats on the new Float!
    #THELEGEND
    2016 RSD Mayor
    2018 Diamondback Release 5C
    2017 Diamondback Haanjo Trail
    dog
    dog is offline
    sit! stay!
    no, it's completely stock other than the spacer... i'm sure i'll be monkeying with the settings for a while, though...
    Mar 2006
    Would you mind posting your settings and ride weight, once you've got it dialed?
    Reputation: gticlay's Avatar
    I just re-set up my Float 180 (riding at 180). I'm at 13 clicks out from closed for both HSC and LSC and a few clicks slower than the manual says for rebound. I cannot run as much sag as they say because it'll be waaaaay too soft spring wise.
    "It looks flexy"
    Mar 2006
    Hope it's not hijacking too much:
    I'm 185ish with gear and run the fork 170mm at 40psi (still don't get proper sag)
    LSC: 15 clicks out from undamped
    HSC: 4 Clicks out from undamped
    Rebound: 13 clicks out from fully damped
    Quote Originally Posted by half_man_half_scab
    You have to count clicks from closed. Forks can have different numbers of clicks from "
    open" or "undamped" but should be all the same from closed.
    "It looks flexy"
    dog
    dog is offline
    sit! stay!
    so far i have been all over the place with my settings except rebound has stayed 2 to 3 clicks from fully fast...
    using Fox's click counting system on the online owner's manual:
    rebound - 15 or 16
    HS compression 6 to 20
    LS compression 3 to 20
    air pressure 50 to 65 psi...
    and that was just in the first ride ... for some reason it seems fairly different from my old (2009) Float 160... so it'll be a while before i zero in on some settings
    oh yeah, i would guess me + gear 160 to 165 lbs (depending how much water i am carrying )...
