DW-link bearing removal
I had some of the bearings on the link of my firebird give out on me. I found the instructions to remove the old bearing and press in new ones on the pivot website (http://www.pivotcycles.com//up/file/...ng-removal.pdf). I tried following those, but I'm not having any luck getting the old bearings out. Anyone have any tricks for getting bearings out?
Bearing replacement
I replaced bearings in my Mach 5 alu two days ago without any problems.You probably need to tap a little bit harder.
- You may not post replies
- You may not edit your posts
Forum Rules
