Results 1 to 2 of 2
    Dec 2010
    DB air canister size for Mach 6
    Looking at Db air CS for my 6, is standard ok or HV recomended?
    OriginalDonk
    Reputation: OriginalDonk's Avatar
    You'll need to special order a CCDBA CS for your Mach 6 as you'll need an open end eyelet design. The part number is BAD0919. CC makes is specifically for the Mach 6 so it'll have whatever will work best. I imagine it'll be standard with the DW-link.
  1. Mach 6 Frame size
    By markmyers in forum Pivot Cycles
    Last Post: 08-19-2015, 04:48 PM
  2. Frame Size: Mach 429
    By SCR818 in forum Pivot Cycles
    Last Post: 05-10-2012, 07:24 AM
  3. Shock canister volume/size
    By surfhb in forum Ibis
    Last Post: 08-05-2011, 05:59 PM
  4. Mach 429 size advice?
    By titusdc in forum Pivot Cycles
    Last Post: 07-28-2011, 10:58 PM
  5. Mach 4 XS Size
    By Oregonic in forum Pivot Cycles
    Last Post: 03-28-2011, 06:16 AM
