Results 1 to 45 of 45
Thread: Creaking Mach ?
    Jamin, Applesause, No?
    Reputation: Senor StrongBad's Avatar
    New question here. Creaking Mach ?
    Who here has had a creaking Mach 5 or 4 or 429 frame? What was creaking and how did you fix it?
    Where is it creaking from. Chances are its the press fit BB.
    Not just famous; infamous
    Reputation: coolhandluchs's Avatar
    Had a pedaling-related creak two rides ago. Pulled apart the cranks and pedals, cleaned and regreased everything, put it back together. Pulled the seat post, and cleaned and greased the post, saddle rails and QR. Also checked the headset and pivot bolt tightness.Took it out on the next ride and the damn thing's still creaking!
    On a whim, I loosened the rear skewer, reset the wheel and tightened the skewer back down. No more creaking.
    Check the rear wheel first. I'm just sayin'...
    Black Lion
    Reputation: yogreg's Avatar
    Recently had an annoying creak on my Mach 5. The noise would only occur while pedaling under power. Went through my normal checklist top to bottom, still the creak persisted. On a last resort I changed out the lower shock eye let bushing and creak gone. Three hard rides later all is still quiet.
    The point I am trying to make is sometimes you need to think outside the box,
    Voltron
    Dec 2009
    The creaks I've had were the seat post and the two large bolts that go through the DW-link. After a regreasing everything has been quiet.
    Paterfamilias
    Feb 2006
    Quote Originally Posted by the-one1 View Post
    Most likely it is not the press fit BB. Our Demo fleet after hundreds of rides rarely have creaking issues at the BB. On other systems like BB30 you are likely to draw this conclusion, but on our system this isn't an issue. Our customer service line doesn't report customers calling about creaking BB units, if they do, it turns out to be a creaking pedal, headset or other item.
    I always recommend to perform a tune and clean on your bikes - most of us MTB riders neglect our bikes and don't clean them as often as we should. We suggest a thorough cleaning at least 2 times a year - more if you are in muddy areas... See the link below for our suggestions.
    http://www.pivotcycles.com//up/file/...es-washing.pdf
    If the noise is still persistent after you perform the above cleaning, I suggest that you start from the front of the bike and work your way back - cleaning and adjusting every item - even remove rotors and cleaning your hubs etc. This will insure that you have cleaned and adjusted every possible surface that could squeak.
    "The face of a child can say it all, especially the mouth part of the face".
    Jack Handy
    "the two large bolts that go through the DW-link"
    This is where mine had some major creaks originating. 2009 M5. There was some corrosion on the pins, cleaned and greased it up and its been very quiet since. Had to pull both the crank and the FD to take them out.
    I have pulled everything apart regreased and tightened to spec and I put a new seat post on it. My B-day was sunday and my wife bought me the new Reverb.
    The creaking persists under heavy pedaling. I reset the rear wheel and tightened it down. The only thing I have not checked yet are the bushings.
    The creaking happens while sitting or standing.
    How do you know if it is one of the bushings?
    I am Doctor Remulak
    Reputation: AZ Mikey's Avatar
    Dd you pull the cassette and apply a light layer of grease before reinstalling? This has solved a hard to find creak for me in the past.
    Quote Originally Posted by AZ Mikey View Post
    No I did not but I will do that tonight!
    My six month old 429 has that painfull creak for 2 months now, worst on climbs and I am guessing it is the bottom linkage as I have replaced the bottom bracket which seized up after 5 muddy months of use by a 120kg rider.
    I am taking it into the work shop latter this week so will report back the cause of the creakedy squeak.
    Strongy
    Pulled it the other night , lubed it up. Rode it on Friday and there was no creaking noise.... AWESOME.... THANKS!
    Most of the creaks on my 429 have been from the seatpost. I regularly take it out, clean it and grease it and it's fine.
    I do have a new and strange creak that I intially thought was from the headset. As it turns out, it's from the crown/steerer on the Fox fork. The sound resonates through the entire bike so it was hard to tell where it's coming from. According to the shop who spent hours trying to find it, it's safe to ride. I guess it's out of warranty so I'm not sure if I want to fork (pardon the pun) out $200 to fix it.
    Update 7/12 - I spoke with Fox customer service. It looks like they may fix it under warranty. Shipping it back and crossing my fingers.
    Professional Slacker
    My cranks were the cause of a creak after about two months of ownership. Tightened, creak gone.
    Reputation: skiahh's Avatar
    Resurrecting an old thread rather than starting a new one.
    I've done all of the above and still have a bad creak/ping when applying moderate to hard power. Regular pedaling, nada. Stomp it hard to accelerate on a flat and it's there. Point the bike up and start really grinding up and it's getting so annoying, I don't want to ride the bike anymore!
    The only thing I haven't done is remove the fork, but I did check all the bolts for correct torque.
    I've disassembled, cleaned, greased and re-torqued every pivot, bolt and moving part. I had the bottom bracket replaced (under Shimano warranty, since one side was notchy). Tightened the seatpost and rear skewer. Pulled the cassette and greased the receiver. Pulled the hub apart and greased/repacked that, too.
    I haven't swapped pedals with another set, but I did pull them apart and clean and repack them (Frogs) with fresh grease.
    The noise happens when standing or sitting. It doesn't matter whether I have weight on the handlebars, have weight off or even pull up the front wheel. But it only happens when applying power. I can plow through rough terrain that fully articulates both the rear and front suspension and it's quiet as a mouse, unless I'm going uphill over the same terrain.
    I have Enve wheels, but haven't tested spoke tension. Could loose spokes (pretty rare on the Enves, from what I understand) make it creak/ping like this?
    I'm still in my warranty period (through December), but the LBS wants to charge me $20/hour to go through all this again and see what they can find. Except the BB, of course, because they did that replacement.
    I understand noise travels through an Al frame, but with that in mind, it definitely sounds like it's coming from the bottom bracket/main pivot area to me and to riding buddies.
    I've even looked for cracks and don't see any.
    What else can I check before calling Pivot for their help?
    Paterfamilias
    Feb 2006
    Do you know if they used loctite when installing the BB?
    If they used grease, there is a chance that the BB is moving under you pedal load.
    You may want to check that.
    Daniel
    Jack Handy
    change is good
    Sep 2004
    Here we go....according to Pivot, the BBs rarely creak and ultimately mine didn't.
    My 429 has creaked in the following areas. I will also list the obvious.
    1. seatpost
    2. maybe seatpost collar. I always lube it when I lube the seatpost
    3. seat. Replaced it with a seat that creaked, which led me to loctite my seat post. Incredibly stupid. This was on my SS.
    4. loose main pivot
    5. propagation of frame crack from loose main pivot
    6. thru axle/bolt needing lube
    7. Ritchey headset
    8. pedals on another bike, but the source was obvious
    9. and lastly, a loose XO crank. The XO and my E13 on my SS requires mucho torque. The XO creak was a beast to discover and I thank my mechanic for finally solving the problem. This was no consistency on how it presented, but typically under power and going up. This was after we did everything you have done. It did come back, and I discovered that approxiamately 50nm of torque is a lot. I did have an old Shimano that creaked a little on my SS, but ultimately the splines wore out, the crank arms would loosen and the BB cups would start to back out. I was shocked. I didn't a Shimano crank could wear out
    My ENVEs didn't creak, even with broken spokes from corroded nipples. My 429 ranks up there with my Ventana as being the quietest bikes I have owned and I am a clyde.
    Quote Originally Posted by dan23 View Post
    Daniel
    Thanks, Daniel - I did not ask them, but I will. I don't think the old BB was causing the creaking, but when I had the cranks out, it was ratcheting (the drivetrain side), so obviously needed to be replaced.
    Quote Originally Posted by DrDon View Post
    1. seatpost Have previously cleaned and coated with grease. Am going to do it again, just to be sure.
    2. maybe seatpost collar. I always lube it when I lube the seatpost Ditto
    3. seat. Replaced it with a seat that creaked, which led me to loctite my seat post. Incredibly stupid. This was on my SS. Good point. I will try a different seat, though if my fizik is creaking, I'm going to be pissed! But given that it does it even when standing, I don't think it'll be the seat. And no locktite on the seatpost; not any color! lol
    4. loose main pivot Checked and rechecked. Plus cleaned and greased.
    5. propagation of frame crack from loose main pivot Fingers crossed, but I haven't seen any sign of a crack so far.
    6. thru axle/bolt needing lube No more through axle; I have a Lefty and the axle is greased
    7. Ritchey headset Replaced with a King from the lunchbox kit, so unlikely unless it was installed incorrectly (same shop that did the BB). Hmmm.....
    8. pedals on another bike, but the source was obvious I need to swap pedals to check. They were making a noise, but once I repacked them with grease, it went away. I suppose it could be back and they need to be replaced completely.
    9. and lastly, a loose XO crank. The XO and my E13 on my SS requires mucho torque. The XO creak was a beast to discover and I thank my mechanic for finally solving the problem. This was no consistency on how it presented, but typically under power and going up. This was after we did everything you have done. It did come back, and I discovered that approxiamately 50nm of torque is a lot. I did have an old Shimano that creaked a little on my SS, but ultimately the splines wore out, the crank arms would loosen and the BB cups would start to back out. I was shocked. I didn't a Shimano crank could wear out I've had them off a couple of times and they're cranked down, but it certainly makes sense, given where the noise is coming from. I can pull them, regrease them and crank them down again.
    It used to be the quietest bike I've owned (until the I9 based rear hub came along), but this creaking - fairly recent - is just driving me crazy! For what it's worth, I'm a clyde, too.
    Thanks for the suggestions! What else might I be missing? What else has anyone seen, heard or found??
    change is good
    Sep 2004
    The thru axle was a rear 10mm on my first 429. The BB was replaced twice. My mechanic used lube for the install, so I destroyed a perfectly good BB when I removed it and replaced it with another with locktite. That's when I discovered the axle as being the cause. The same creak appeared from my new 142 axle, but hey, I caught that one quick.
    Oct 2012
    I read that a common culprit is the rear derailleur hanger. Either where the derailleur mounts or where the hanger mounts, to sure which. That would makes sense under heavy power....
    Hmmm... I'm not sure what the rear on mine is. I always thought it was a 9mm with that DTS ratchet system. But it's not a "thru axle" if I can remove it without taking the axle out, right? Whatever it is, it does loosen up just enough to add to the noises, though, and I don't much like it. That's the first thing I check and it frequently needs tightening, but that doesn't quiet the bike.
    Quote Originally Posted by Crash-VR View Post
    Thanks, Crash - I hadn't even thought of that. I'll clean, grease and reinstall mine and see if that helps.
    Nov 2008
    This problem started to occur recently for me and my mach 5. It was perfectly silent until the last month or so. I do admit I have washed a couple of times. What I noticed is if you just pounce up and down sitting on the bike and compressing the shock there is no creak. Once I do go out and pedal up hill with pressure there is a creak. Now off the bike, if you hold the brake and rock the bike forwards and backwards, the creak happens. I think its in the lower pivot. At first I thought it was in rear hub or qr but its not.
    change is good
    Sep 2004
    Creaking Mach ?
    Try lubing the shaft of the bolt if you haven't yet.
    Reputation: joshdurston's Avatar
    Feb 2010
    I had a creak related to not having grease around my headset bearings (the bearings were fine internally by where they interfaced with the headset it creaked on weight shift and pedal strokes. The sound didn't sound like it was coming from the headset at all, but wiping all the bits clean and reassembling with a tacky grease solved it for me.
    Another point of creaks for my has been the shock mounting hardware when I was running a RS Monarch Plus. I'm running the same hardware now in my RP23 with complete silence. Cleanliness, proper torque and a bit of high quality grease seem to work wonders.
    Well crap. Took the crank off to clean and regrease the lower pivot bolt and what did I see?
    Light wasn't good in the garage tonight and the macro mode may or may not be picking it up, but it looks like a small crack. Left side where the chain stay and that vertical piece come together.
    I'll take a new look in the morning, with better light and after I scrub it with a toothbrush to make sure I'm not just seeing dirt in the weld seam. And take some more pics, too, with sunlight on things.
    But if it's not a crack, then seat post, collar and pedals checked OK so far. Removing, cleaning, regreasing and retorqueing (or however you spell that!) the pivot bolts next.
    Reputation: engrmariano's Avatar
    Creaking Mach ?
    Quote Originally Posted by coolhandluchs View Post
    may be some sand & dust inside the lower pivot bearing assembly... i had the same issue with my 429c (i've posted the issue at 429c thread). my lbs thought it's the bearing issue & they've ordered replacement bearings for my bike. but when they're about to replace it, the mechanic found a lot of sand around the bearing assembly. he cleaned & it's sound free. i asked "that thing is exposed to mud & dirt, for sure it could happen again." the mechanic told me that they did something and assured me that it wont happen again.
    PIVOT
    Well, after cleaning I couldn't be sure it was a crack, so I took it to the LBS who went through the same steps as I did and they couldn't definitively say whether it was a crack or not. They're willing to box up the rear triangle and ship it off to Pivot, but I'm going to finish this part by part relubing and retorquing first, just to be sure.
    This is driving me crazy!
    change is good
    Sep 2004
    Ok, I'm reaching,but here goes
    - I found a 1cm crack at the top of my Tallboy carbon seat tube when I removed the seat post when the bike was wet. It happened again on the warranty triangle.
    - The seat tube of my Scalpel carbon ovalized. Who knew?
    - Try a different post and/or new seat if you haven't before
    - New or old cleats
    - Shoe sole contacting pedal
    - Or just suck it up, you're a clydesdale! Our bikes are supposed to creak. Do you miss your alloy 429 yet? Just messin with you. My experiences with the multiple Tallboys and Cannondale's lack of response has traumatized me forever to the point that I need therapy. Good luck
    11 is one louder than 10
    Reputation: Green Giant's Avatar
    First Tallboy - cracked the rear end at a lower pivot, subsequently cracked the seattube as did Don. Had that bike 1 season.
    Second Tallboy (really dig tallboys) - one season, only cracked the carbon link of all things.
    Have not cracked my pivot, and I believe (hoping, praying) that it turned out to be a creaky crown on my fox fork (which would be no shock as I've had several).
    I did clean my rear pivot and still had the creaking, but now think it might have been the fork.
    Tallboy was always dead quiet, I'll give it that. I'd also have no problem owning another as SC was always great.
    But had a ride today with my other fork on the bike and it was pretty quiet. Trying not to over analyze it. Adore how the bike rides though.
    "The thing is, Bob, it's not that I'm lazy, it's that I just don't care."
    OK. Might have been the front bolt on the main pivot. It was pretty dry and a LOT tighter than I set it when I had it apart last time. After cleaning, regreasing (with a thicker grease, I'll add) and re-torquing it sounded mostly quiet. A fresh coat of chain lube cleared up the last of the noise and now - for the time being - it's nice and quiet again. Woohoo!
    Got to take it out on a shakedown cruise today (lots of rain recently) and while it's a lot quieter, the creak/ping is still there at times. Ugh! Fork coming off next for cleaning, relubing and reinstallation.
    Well,
    No doubt this is really frustrating.
    I changed my fork and that helped a bit, I had a double whammy going on as I had a fox fork with the dreaded creaky crown. I seem to hit at about a 50% rate on fox fork crowns creaking.
    But, I still have a consistent creak remaining. I've basically at this point torn the entire bike down and rebuilt it. If it can be cleaned and greased - I've done it. Changed pedals even.
    I can seem to quiet it down for a ride but it comes back so quickly. Incredibly frustrating.
    I love how this bike rides. Quite possibly my favorite 29er yet. That said I hate creaks (i can deal with some here and there) but this is insane. I'm contemplating returning it to competitive cyclist and going with something else. Frankly, in the past I would have done that already as I've basically rebuilt the bike 2x, but the ride quality is that damn good so I'm really trying to sort this out.
    Quote Originally Posted by Green Giant View Post
    Well,
    Have you given Pivot a call? Aaron B has been working with me to troubleshoot things and has had some good suggestions that I hadn't thought of.
    Quote Originally Posted by skiahh View Post
    Yes, pivot has been EXCELLENT in providing support.
    Well, headset disassembled, cleaned, lubed and reassembled. Still creaking. More of a pinging, I guess I should say.
    Shock removed, bolts cleaned, greased and reassembled. Still pinging.
    Crank bolts tightened. Still there.
    Put a different rear wheel on and it's still there!
    Even tightened up the water bottle bolts (top and bottom of the down tube). No joy.
    Tomorrow, I'm going to remove the link (again) and replace it with the original link; I have a Lunchbox kit.
    Anyone think of anything else at all???
    Looks like the culprit is the SL link from the Lunchbox. I have the original link installed right now and on a very short test ride this morning, it was nice and quiet. Longer ride later today or tomorrow to be sure.
    The Pivot crew is heading to Dealer Camp (I got an email from them today - Sunday!), so I'll just ride the original link until they get back and we sort the rest out.
    Thanks for the help everyone, and Pivot!
    Think... I think I found it.
    Well,
    Think I found it today - finally.
    I believe it's coming from the XX1 rear derailleur of all things.
    whenever pedaling or compressing the suspension (pedaling or not pedaling, it or out of the saddle) - creak.
    held the right seatstay in my hand and compressed - felt it.
    tried everything - still creaked.
    Pulled the rear derailleur completely off - no creak.
    man, while that would stink on one hand - I'm praying that is the case. Because I'm going to switch drivetrains here and see if that does it. I've seen a few other reports of creaky XX1 rear derailleurs... maybe this is one.
    Here is hoping! Love this ride otherwise.
    guess I'm not the only one...
    SRAM XX1 Noise Problem - YouTube
    Update. Just did my second creak free ride. I had a couple going on. The fox fork crown but that one was obvious.
    The second appears to have been the rear dérailleur. I pulled it as mentioned. Cleaned the threads and the back surface of the mounting area aong with the der hanger. Liberally applied grease to the bolt and both mounting surface areas. Reinstalled and so far it's been dead silent. Great news as this bike rides so darn well.
    Creaky Fox fork?
    What fork are you using?
    After trying everything else mine was the steerer tube on my 2011 Fox fork. This is a known problem, just do a search creaking fox fork and you will find several pages worth of information.
    Green loctite approach is working for me so far.
    Quote Originally Posted by Kendo View Post
    Thanks, I use a Lefty which doesn't make any noise. And the headset is tight.
    It's the SL link from the Lunchbox link. Not sure whether it's the pins that go through it or the carbon insert coming loose, but with the original link installed, there's no creak anymore.
    OK, it was the SL link and/or pins.
    Pivot was fantastic in helping me check some things I hadn't thought of and with ways to test them out. Ultimately, they asked me to send the link and pins back in for them to check out. They sent pins back because the old ones were on the high end of the diameter spec. They also replaced the bearings in the link and sent it back and now no noise with the blue bits back on the bike.
    Great job Pivot, and thank you!!
    Aug 2013
    Mach 4 creaking
    Quote Originally Posted by Senor StrongBad View Post
    Yep my Mach 4 has done this a few times, every time it has been the shock. The first time the shock 'can' was not tight (from brand new). Every other time it has been the rear shock bolt, where I have applied grease to the entire bolt, including where the shock bush pivots. Hope this helps
    Dec 2008
    G'day,
    Fox crowns are creaky per se. I had one replaced, with a promise that the newer one would not creak and guess what! yep the new one creaked.
    Save yourself some pain and trouble and buy some Boe-shield or similar lube. Flip the bike over and rest it on the bars/saddle. Drip the Boe-shield down the stanction toward the stanction/crown interface so that it fills the gap- fox stanctions are press fitted into the crown and the lube fills that gap. Let the bike sit up sidedown for an hour or so to make sure the lube penetrates. This has solved the creaky fox crown on four pairs of my Fox forks- hope it works for you!
    Quote Originally Posted by rtcage View Post
    Reputation: SDMTB'er's Avatar
    Feb 2014
    Just resurrecting this.
    I had a pinging / creaking noise on my Mach 429 Carbon that only made a sound when climbing. It sounded like it was coming from the headset area.
    I solved the problem by:
    Removing seatpost and thoroughly cleaning post and clamp. I have a KS LEV seatpost so I used carbon paste and put that on the post before putting back in. I also rotated the seatpost clamp so that the screw faces away from all the dirt that kicks up from the rear tire. Caution: don't over tighten when using a KS LEV. It will interfere win the seat going up and down properly.
    Loosened the the two blue Allen bolts that secure the rear shock, re greased those and tightened.
    Loosened rear quick release and re greased rear axle and inside of dropouts. Re tightened rear quick release as tight as I could turn it.
    Loosened rear derailleur hanger bolts and greased surface of rear derailleur hanger. Re tightened.
    Disassembled entire front steering assembly and re greased all collars. Re assembled making sure headset was tightened properly (no wiggle).
    One of those things fixed it. Entire process took about a half hour. If I had to guess what the problem was it would be the seatpost.
  1. Ibis Mojo SL vs. Pivot Mach 5 vs. Pivot Mach 429
    By ktothetothe in forum All Mountain
    Last Post: 12-13-2010, 06:20 PM
  2. Old mach 4 vs new 2011 mach 4?
    By Ansible in forum Pivot Cycles
    Last Post: 10-13-2010, 07:39 PM
  3. Weight: Mach 4 vs Mach 5 ???
    By Rollin'in'Zona in forum Pivot Cycles
    Last Post: 12-12-2009, 03:53 PM
  4. mach 5 chasing mach 5
    By supermoto in forum Pivot Cycles
    Last Post: 04-09-2009, 04:10 PM
