Special Lister
Cranks for a Phoenix
I have a stock set of Truvativ Descendant cranks on my Phoenix and want to replace. If you have a different set what do you have and do you like them?
I run Saints on mine, pretty much the "Gold" standard. They do cost a bit more but the performance is worth it IMO....
Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
Saints, perhaps a little bit boring, but you can't go wrong, also the most rigid crank I have ever used.
The only thing I would change on my phoenix, is to perhaps go to a 165 from a 170, I tend to 'just' clip obstacles with the pedal/crank all the time.
I agree with this. Riding today I noticed the Phoenix seemed lower than other bikes I have ridden. Riding the same trail I just took the Glory on I kept hitting my toes on stuff. At one point I even jammed my foot into the ground. Part of this is because it wasn't very steep so I was pedaling through turns a lot.
2011 Giant Glory 01
2013 Pivot Firebird
2004 Turner Rail - Stoled
I ran RF SIXC on mine, lovely and light as heck but certainly not a budget item. RF Atlas are had to fault if you like some color and as kenbentit mentioned, Saints are nearly infallible. So, Race Face or Shimano are the safe bets, pick your poison.
Special Lister
Got a set of M815 Saints. Jenson sent the wrong set. I was supposed to get the M815 without rings and bash guard...that was the one on sale. Well they sent the one with ring and bash guard. Which is fine with me. I am just not sure if i wanna take the bash gaurd off and use my E13 system or leave the bash guard on and get a Blackspire stinger for a tensioner.
- You may not post replies
- You may not edit your posts
Forum Rules
