Results 1 to 17 of 17
    TCB
    TCB is offline
    Reputation: TCB's Avatar
    Dec 2004
    Cracked Firebird frame
    Has this little issue with the Firebird been resolved, I bought
    the frame about a year and half ago, I sent the frame back to Pivot yesterday so I should get a replacement by next week.
    "No matter where you go there you are" BUCKAROO BANZAI
    Proud Thunderchicken ownr
    Reputation: btibben's Avatar
    Is that right where the new upgrade brace resides? I'm wondering if I should request one ...
    Common sense is not so common - Voltaire
    Never underestimate your own ignorance - Me
    dog
    dog is offline
    sit! stay!
    Reputation: dog's Avatar
    ^Yes, that's the spot... and i agree you should...
    i need to develop my crashing skills...
    Yep, the newer ones have a gusset that reinforces the frame. There is a retro-fit part that can be installed by pivot. Mine is a 2011 and has that gusset. Look at the second picture in this link and you can see it. CCDB Air and the Firebird. No-go.
    TCB
    TCB is offline
    Dec 2004
    Would you know if my dhx coil will fit with the upgraded gusset, if it doesn't I might go with the new FLOAT X
    I do not know if it would fit. But from what I have read about some people running coil shocks, I'd guess that it will fit. But that's just that...a guess. There are a few coil FB guys around here, maybe someone with some experience can chime in.
    Dec 2010
    I've got a DB coil on my '09 bird with the gusset fix, doesn't get in the way at all. And if I'm not mistaken, the spring on the DB has a larger diameter than on a Fox so you should be good to go once you get it back.
    PMarsh Thumbs Up!
    Reputation: StuLax18's Avatar
    I know the demo guy, Josh, has a DHX coil on his FB, with the carbon rocker I believe. I was surprised to see it fit.
    2011 Giant Glory 01
    2013 Pivot Firebird
    2004 Turner Rail - Stoled
    Paterfamilias
    Feb 2006
    This has been resolved. You can get a free upgrade to your older models, call PIVOT or your dealer, they can help you.
    The newer frames 2012 and 2013 all have a welded box section there to eliminate that from happening.
    If you run a coil shock, you may need the alloy rocker, as the springs won't clear the carbon rocker.
    "The face of a child can say it all, especially the mouth part of the face".
    Jack Handy
    TCB
    TCB is offline
    Dec 2004
    I sent the Bike to Pivot on the 18th and it's still in the queue waiting to be looked at, does it usually take two week or longer to get the frame back from pivot.
    I was hoping to do some riding this weekend.
    Paterfamilias
    Feb 2006
    Quote Originally Posted by TCB View Post
    Have you called your dealer, or called us? Depending on where you shipped from it can take up to 5 working days to get to us. We generally turn it around within 24 hours of receiving it.
    Call and talk with Brien, Todd or Aaron, they should be able to tell you exactly what is happening with it. 480-467-2920
    Daniel
    Jack Handy
    TCB
    TCB is offline
    Dec 2004
    Quote Originally Posted by dan23 View Post
    Daniel
    I called Pivot and they never received the Frame so then I called back the Bike shop, the Bike shop tracked the FedEx # and the tracking history only showed The FedEx driver picking up the frame, so now FedEx is doing a trace.
    Thanks Daniel for posting the contact info.
    TCB
    TCB is offline
    Dec 2004
    Update.
    FedEx found the Box with the frame in it, they said it was hiding behind other boxes, probably hiding behind the Lost Ark.
    So hopefully FedEx will deliver the frame to pivot by Monday if they don't reroute it to China.
    Reputation: rehammer81's Avatar
    Jun 2010
    Re: Cracked Firebird frame
    Freaking FedEx kills me. They delivered my last new frame to the vacant house across the street. I checked the address on the box, yep, my correct address. Somebody couldn't read. Didn't get home until the evening when it was starting to get dark. Was freaking out that somebody stole it off my porch. Then I luckily saw the shadow of the box across the street. Geez!
    Specialized Epic 29
    Intense Tracer 29
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Dang! I'd make friends with a local business (bike shop, bakery, whatever) and have the important stuff delivered there. My own horror story; Ordered a Gibson 50th Anniversary Flying V. Kept checking delivery status so I'd be home to sign for it. No problem, they just left the big box with "Gibson" logos all over it right by the front door, in the middle of summer in Phoenix. Yet my wife has to sign for a $500 laptop??
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    TCB
    TCB is offline
    Dec 2004
    Got the Frame back, Pivot mailed the frame back the same day they received it, they also upgraded the rear triangle to the newer 142mm x 12mm thru-axle
    A big thanks to Pivot and my local Bike Shop "itsa bike shop" ITSA Bike Shop - In San Diego, It's The Smart Alternative!
    And to Fedex
    Pivotal figure
    Jan 2003
    Ha!
  1. What's wrong with this picture?
    By MaddCelt in forum Commuting
    Last Post: 06-15-2013, 09:19 PM
  2. What's wrong with this picture ?
    By serhij in forum Turner
    Last Post: 12-11-2012, 07:21 PM
  3. What's wrong with this picture?
    By whizbyu in forum 29er Bikes
    Last Post: 06-06-2012, 04:56 PM
  4. What's wrong with this picture?
    By tortfeasor in forum Turner
    Last Post: 03-30-2012, 02:19 AM
  5. What's wrong with this picture?
    By UncleTrail in forum Colorado - Front Range
    Last Post: 11-15-2011, 01:05 PM
