Results 1 to 6 of 6
    Reputation: Vosh's Avatar
    Cleaning Mach 6 and water getting inside the frame
    Hello,
    Does anyone else end up with water splashing about inside the frame after a good wash? Living in Scotland, it's needing a few washes what with the variable weather we get. Once finished I can hear water inside the frame. Can tilt it upside down and some dribbles out the unused cabling holes, but can't get the rest out without having to pretty much remove the forks. Seat post is stealth cabled and at the exact point where I want it and don't want to have to pull it out every time.
    Any tips/ideas?
    Cheers.
    If you are using a 1x, cover the unused hole for the front derailleur. That is where the water is getting in.
    Oh I know where the water is getting in, it's just the easiest way of getting it out! Which I think is forks or dropper post off and empty it.
    change is good
    Sep 2004
    Quote Originally Posted by aevanlloyd View Post
    Electrical tape rolled into a little plug. Doesn't look that bad. Water in the frame can be a bad thing. Ironically it's not the frame material I'm worried about but the BB and possibly the dropper. Also eventually the seatpost will probably creak. Other manufacturers offer plugs.
    Aug 2010
    get some black gasket maker=silicone... from your local auto retailer and apply accordingly in the holes that are not utilized.
    I had the same thing happen. Pull your seat post out and flip the bike over. That's the quickest way to get the water out. You don't have to disconnect the dropper cable, just carefully hold it while you flip the bike.
    Once the water is back use the tips above to keep the water out.
  1. Replies: 15
    Last Post: 11-21-2013, 07:02 AM
  2. cleaning bike with softened water?
    By jbourne84 in forum General Discussion
    Last Post: 06-10-2013, 08:18 PM
  3. Cleaning/Sanatizing Water Bladder
    By BigGK in forum Apparel and Protection
    Last Post: 05-25-2013, 12:24 PM
  4. Replies: 9
    Last Post: 09-27-2012, 11:34 AM
  5. cleaning INSIDE the lowers...
    By Uncle Six Pack in forum Shocks and Suspension
    Last Post: 02-01-2011, 09:17 PM
