Page 2 of 2 FirstFirst 12
Results 51 to 83 of 83
  1. #51
    change is good
    Sep 2004
    Clarifying Mach 429 Tire Clearance - from Chris Cocalis
    My new Ground Control 2.1 fits with plenty of room. It's a skinny tire.
  2. #52
    Mar 2013
    650b fixed mine....! Pivot Mach 427
    good thing I bought mine to convert anyway...didn't notice the clearance problem at the shop when I purchased it...owe well Pivot 427...? .................................................. ................... ok here are some pix of the finished bike.......! after first test drive it feels awesome..........! roll's just as fast as my 29er wheels but feels way more nimble and lighter, I may have just hit the G-spot, I ordered a lg. frame, usually I ride med. but the 3/4" drop made it perfect and BB is at 12.5, ok..! but now plan on a FOX 34 TALAS 650b fork with 160mm should bring thing in focuses and slack the head tube some...! also plenty of room for fat tires, Schwalbe Hans Dampf 27.5-2.35 or vee-rubber 27.5-2.4's
    Attached Thumbnails Attached Thumbnails Clarifying Mach 429 Tire Clearance - from Chris Cocalis-imag1257.jpg
  3. #53
    Dec 2009
    Quote Originally Posted by scaddoo62 View Post
    That looks like the first great use of this frame I've seen.
    I sold my 2012 429 for what amounted to a song. In some ways I'm sorry because nothing rides like that bike that I've ridden since and in some ways I'm happy because I don't have to constantly compromise my tire selections based on frame clearance.
    I'll be curious to know how the bike rides as a 650b. I hope it works out because that would be the case to get another frame and build it out.
  4. #54
    change is good
    Sep 2004
    Thank God I really like GC Grid. It handled east coast rocks and roots with ease and didn't deflect much like some lower volume TLR tires.
  5. #55
    Mar 2013
    updated my first reply with new pix and first test drive info..............
  6. #56
    Dec 2009
    The Mach427 ROCKS! Nice work.
  7. #57
    Reputation: silent713's Avatar
    Feb 2006
    Quote Originally Posted by dan23 View Post
    Everyone:
    We have had some questions regarding this thread and wanted to go on a set the record straight. First, in general we designed the new 429 to clear a wide variety of tires. Below is a pretty comprehensive list of tires that fit the 429 Alloy frames without any issues. When we redesigned the 429 AL, the new rear triangle we increased stiffness by over 20% and maintained proper tire clearance for the category.
    We try our best to measure a wide variety of tires but (as most people know) sizes are all over the board and sometimes the height of the tire and the brand and/or width of rim that is used can create additional challenges. In the case of the Hanís Dampf, that tire is over 6mm taller than ANY other tire we tested regardless of stated size. It is not the widest tire but it doesnít fall into normal standards. However, as you can see from the below list, the WTB Weirwolf 2.55 clears and is actually lower in height (but wider in width) than some of the 2.2ís including the Slant 6. The Maxxis Ardent 2.35 also has great clearance. If you are looking for a more aggressive trail oriented tire for your current 429, there are some great choices and by no means is this the total list of tires that will fit. This is just our current list of tested and confirmed tires which will grow as we get more samples to check.
    If you are looking at buying a 429 aluminum, you can rest assured that we have sold thousands of these bikes with the new design and have not had negative feedback as to tire clearance issues. We did experience a very small number of frames that went out without the proper tire clearance that only affected a handful of customers. We took care of these immediately and as far as we know, all bikes in the market should be at the proper specification. If anyone has an issue with clearance on any of the tires listed below, please contact us directly and we will correct the situation. As always, we stand behind our products and want our customers to know that we are here to help if questions arise.
    Hutchinson Cobra 2.25 tubeless
    Kenda Slant Six 2.2
    Kenda Honey Badger 2.2
    WTB Wolverine 2.2 tubeless
    WTB Bronson 2.2 tubeless
    WTB Stout 2.3
    WTB Weirwolf 2.55
    Maxxis Ardent 2.35 tubeless
    Maxxis Ikon 2.2
    Conti Race King 2.2
    Conti Mountain King 2.2
    Specialized Eskar 2.3 tubeless
    Specialized Purgatory 2.2 tubeless
    Sincerely,
    Chris Cocalis
    Very glad/interested to see this info. I was about to pull the trigger on a '12 429 frame, then decided to look into tire clearance, as I wanted to run somewhat high-volume tires. You stated above that if anyone has fit issues with the tires you listed that you will correct the situation. Does that only apply to '13 frames and/or newer, or would it also apply to a '12 frame? The tire I have in question is the Racing Ralph, so any feedback/info would be appreciated. Thanks!
    A man who carries a cat by the tail learns something he can learn in no other way.
  8. #58
    Reputation: ElDuderino2412's Avatar
    Oct 2012
    Quote Originally Posted by silent713 View Post
    The racing ralph 2.25 should fit. The 2.4 probably won't fit. I run 2.25 Rocket Ron on my rear, and i believe the Ralph's are a little lower profile. I think if you read through all the postings someone said the the RaRa 2.25 fit.
    2012 Pivot Mach 429
    2010 Cervelo R3 SL
  9. #59
    Rider down under
    Reputation: Hugor's Avatar
    Disappointed in a big way.
    I'm running a 2013 frame.
    2.2 RaRa's coped fine in the summer but properly clogged up in seconds at the first drying puddle I came across. The remainder of the ride was frequently interrupted by wheel clearing exercises.
    Its no good providing a list of tyres that will fit, but rather a list that will handle some mud. It is an off road bike after all!
    To have such an expensive bike resigned to dry summer riding is a big waste.
    I find it hard to reconcile that this flaw has been present in the last 2 generations of this frame but not addressed in any way.
    After only 500 kms I am now considering moving my bits to another frame.
  10. #60
    change is good
    Sep 2004
    Ground Control 2.1
    Mountain King II 2.2
    Pending Gato 2.1
    If you prefer high volume you're out of luck. From personal experience the GC and MK clear clay mud decently but of course are not dedicated mud tires. No one runs mud tires where I ride because water saturated clay mud clogs them. A tire that is equivalent to the RaRa in speed and of course is not an optimal wet tire is the X-King 2.2. It will get you through those muddy patches without gunking up your frame.
  11. #61
    Rider down under
    Quote Originally Posted by DrDon View Post
    Ground Control 2.1
    Pending Gato 2.1
    Thank you for that.
    Will try the X-king 2.2. Seems to get good reviews.
    Always used my summer tyres all year here as its never muddy for long enough to justify seasonal changes.
    My RaRa's are about 80% worn so a new one would be impossible to ride in anything but the driest conditions.
  12. #62
    Aug 2013
    Has anyone actually run the WTB Bronson on their 429? If so, would you post a pic of the clearance. Thanx.
  13. #63
    Reputation: (Tom)'s Avatar
    I ran a Bronson on a WTB i23 rim. It fit but it was tight. Sorry no photos.
  14. #64
    Aug 2013
    Quote Originally Posted by (Tom) View Post
    Did the Bronson rub at all?
    I wonder if a 2.25/2.1 f/r combo would work with good clearance out back?
  15. #65
    Aug 2013
    Quote Originally Posted by ElDuderino2412 View Post
    Did you think the RoRo in 2.1 would provide increased clearance for the rear? How do you like the RoRo overall?
  16. #66
    Reputation: juan_speeder's Avatar
    Is there more tire clearance on the 429 Carbon?
    Supply Side Jesusnomosist
  17. #67
    Aug 2010
    Quote Originally Posted by juan_speeder View Post
    Yes there is, 2.35" Hans Dampf fits just fine.
  18. #68
    Dec 2014
    Maxxis Ardent 2.25 fit
    I know the official Pivot response says the Ardent 2.25 fits (the normal version, not the race version), but have any of the riders ridden that tire on the 429A? I would be interested to see how it goes and if you have had any issues. Thinking about buying this bike and that is a tire I am perfectly happy with.
    Any one has tried WTB Trailblazer 27.5 + tire with WTB Scrapper wheel on the 429 alu frame?
  20. #70
    WTB wolverin 2.2
    WTB wolverin 2.2 on late 2012 frame
    with 30+ psi ( desert ride with allot of sharp rocks)
    the tire touche the frame had to deflate
    after big rock hit the wheel and the wheel lost alignment
    the tire start rubbing the frame
    Attached Thumbnails Attached Thumbnails Clarifying Mach 429 Tire Clearance - from Chris Cocalis-2014-12-19-20.55.56.jpg
  21. #71
    Reputation: puspouch's Avatar
    Dec 2005
    I'm running WTB Trailblazer 2.8 x 27.5 on a 2010 429 (now fat 427?) frame. No tire clearance issues. Wheels are Pacenti TL28 (i23). Great fun!
  22. #72
    Dec 2005
    Fat 427
  23. #73
    These are the tires I've been running for the last two years. They fit fine, no issues, and work well with the bike for trail and endurance racing.
    Quote Originally Posted by Greg6327 View Post
    Low speed, High Drag
    Reputation: kevhogaz's Avatar
    Is there any difference in tire clearance a 2014 frame?
    I'm getting ready to build one, and very obviously the Conti Mtn King 2.4 won't fit on the frame. Should I get another Conti, but in 2.2, or will a Schwalbe Nobby Nic 2.25 or 2.35 fit on there?
    Wish i would have done more research on this tire fitting problem. I love running bigger tires, since I'm a fat a$$ who needs the extra tire!!
    I need a cool saying to put here.
  25. #75
    Turns right to go left
    Reputation: 410sprint's Avatar
    Oct 2012
    Quote Originally Posted by kevhogaz View Post
    Is your 2014 Carbon or Aluminum? The carbon, yes, more room. The Aluminum, not sure they changed it...
  26. #76
    Quote Originally Posted by 410sprint View Post
    Oops, aluminum!! I'll go with the 2.25, just to be safe!!
  27. #77
    Reputation: AZ Stumpy's Avatar
    Nov 2008
    I just test fit a 2.35 nobby nic to my 2014 429 alloy and it actually fit. Not a lot of room to spare but it will work. If you are running flexy wheels it will rub a little I suspect. I don't ride mud and I have carbon wheels so I'm gonna run one when the desert eats my 2.25 rocket ron (doesn't take long).
    Those 27.5 429a setups sound pretty sweet.
  28. #78
    change is good
    Sep 2004
    The old NN 2.25 wouldn't fit. The 2.2 MK fits. The 2.25 Ardent will fit. I personally think the 2.25 EXO Ardent gets a bad rap as a install and forget rear trail tire, especially during the dryer months. It and the 2.4 are only overwhelmed on longer travel AM bikes and too much tire on non techy trails.
  29. #79
    Quote Originally Posted by AZ Stumpy View Post
    Interesting. I went out and looked at mine, and with a 2.25 Nobby Nic, I've got minimal clearance, at best. It never rubs, and I'm running DT Swiss rims, so flex isn't really a problem. I've got plenty of room at the chainstays, it's the cross bar that makes the fit tight. I might have to try a 2.35 next!!
    Mine with the 2.25 NN
  30. #80
    Nov 2008
    I wish I woulda snapped a few pics. Check back in a few months when I need a new tire.
  31. #81
    Yeah, I'd like to see how much clearance you get with the 2.35.
  32. #82
    Nov 2008
    Here's the 2.35 Nobby Nic. It barely fits but it does. I had to dish the wheel a smidge to make it work. Everything pretty much has to be perfect. I wouldn't try this in the mud or with a flexy rim.
  33. #83
    Yeah, I'll just stick with the 2.25!! I haven't noticed any reason to change it, so it'll be the tire until I get a new frame!!
