Chris King headset?
Printable View
  • 11-05-2012
    Mach57
    Chris King headset?
    can someone confirm for me that the correct CK headset for my Mach 5.7 is the inset #2? thanks.:)
  • 11-05-2012
    kenbentit
    Not sure which link you're looking at for that Inset# but you just need to order the 44mm upper & 56mm lower inset.
    Chris King InSet
  • 11-06-2012
    dan23
    Follow this link:
    Chris King 44/56
  • 11-10-2012
    mtbnozpikr
    I just put one in mine and yes it is the Inset 2.
  • 11-17-2012
    stew
    Dan or Ken, would that be the same Inset for a 2011 429?
  • 11-17-2012
    kenbentit
    Yep, the older frames without a tapered head tube will use a 44mm upper & lower cup. Tapered head tubes are 44/56 (for our frames anyway...).
  • 11-19-2012
    dan23
    If you follow the link Inset 44
    You can see there is an option for 1 1/8 forks, and tapered 1 1/8x1.5 forks. So you can still run tapered forks on the older style frames.
