Results 1 to 6 of 6
    Dec 2010
    Cane Creek Double Barrel air on a M.57?
    Hi
    Been wondering for a while if it was possible to fit the new upcoming Cane Creek Double Barrel Air onto a Small size M5.7? Been using this bike for a while, and one of my main gripes with what could have been a perfect rig was the RP23 that came stock with it. The damn shock seems to blow through its mid travel too easily, and attempts to firm it slightly renders it losing its small bump compliance.
    Hence, given that i would also be changing the stock 140 float to a Lyrik sometime at the end of this year, i figured that if it was possible i might as well get a CCDB Air as the same time which may get me a better discount from the LBS
    If its possible, what are the shock specs that i need to look out for?
    For example eye to eye length, shock stroke and any specific tuning as well?
    Reputation: GhisalloWheels's Avatar
    Oct 2007
    If I were you, I'd talk with PUSH about their Monarch custom tuned to you and your bike. I had some of the same issues with the rp23 on my firebird. I went to the Monarch and fell in love with my bike all over again. My guess is that your a bigger guy. The custom tuning will take that into account.
    Cycle tracks will abound in Utopia. ~H.G. Wells
    Black Lion
    Reputation: yogreg's Avatar
    A push'd tuned Monarch RT-AM is what you should strongly look into
    Voltron
    Ghisallowheels and yogreg...I had my Fox Float Pushed on my FB and it feels great. I have been thinking of doing the rear shock as well. Can you tell me in what ways the Pushed Monarch is better than the stock Fox Rp23?
    Black Lion
    Quote Originally Posted by jason300b View Post
    Couple of points:
    Stock for stock the Monarch is a superior unit than the Fox RP3. Having a Monarch custom tuned (push'd) brings this shock to another level.
    A cheaper alternative is to get your RP3 custom tuned (push'd), it will out perform a stock RP3 in every way.
    A Push'd Monarch will out perform a Push'd RP3,
    The Monarch offers a more refined spring curve as well as larger oil capacity and piston area. Because of this you can run lower pressures and the damper is more tuneable. The Monarch also utilizes a new Solo Air system that has a transfer port that automatically sets the negative pressure to exactly balance it with the positive pressure that you put in.
    Hope this helps a bit
    Greg
    Voltron
    Thanks for the info.
  1. Should I buy a Cane Creek Double Barrel?
    By jfinch23 in forum All Mountain
    Last Post: 01-08-2010, 01:45 PM
  2. cane creek double barrel on an M1
    By daisycutter in forum Intense
    Last Post: 12-04-2007, 04:52 PM
  3. Cane Creek Double Barrel on EVO
    By Nevegal in forum Custom Builders & Other Manufacturers
    Last Post: 09-01-2007, 01:28 PM
  4. Cane Creek Double Barrel
    By HKG CHAMELEON in forum Shocks and Suspension
    Last Post: 06-18-2007, 07:59 AM
  5. What do you think of the new Cane Creek Double Barrel?
    By acdcfan1283 in forum Downhill - Freeride
    Last Post: 10-18-2005, 03:49 AM
