    Reputation: Mike Aswell's Avatar
    Brake Hose Length
    Dumb question, thought I would put it here rather than the brake forum as it is somewhat specific to Pivot.
    I am looking to purchase hydraulic brakes to replace old BB7s on my Mach 5. Frame size is small. The system I am looking at is pre-bled and I would prefer not to have to mess with the hose length if I don't have to. So my question is, for a small Mach 5, what length hose for the rear brake line? Will 1300 mm be enough?
    Any advice would be appreciated. Thanks.
    Reputation: onegymrat's Avatar
    Most standard hoses that come with your new hydraulic brakes will be plenty, if not too much, for your frame. I wouldn't worry about it too much. You may find that you want to shorten the hose eventually in the future.
    Thank you for the response. I took some quick measurements and thought I would be okay, but going from mech to hydraulic I wasn't sure if you would want more/less/similar amount of slack/play in the hose compared to cables.
    Thanks again.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Small Mach 5 would need 48.5" for the rear hose, 29.5" for front.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
