Results 1 to 12 of 12
    Reputation: katen21's Avatar
    Sep 2012
    Bottom Bracket Replacement
    Hi all,
    I own a M5.7c and will be replacing the bottom bracket for the first time. Will be using a Park press fit to remove and install a GXP BB92. Any tips/tricks, and anything this noob should be aware of? Thanks in advance.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Removal is the "fun" part but pretty similar to removing headset cups. The dust sleeve can make it hard to remove the BB cups but that's about the only real challenge. Installation is also simple. We do recommend using blue Loctite on the cups to eliminate any creaking and I like to install one cup at a time just to make sure nothing gets crooked on the way in.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Sep 2012
    Specifically where on the cup is the loctite applied? What tool do you use to press them in? Thanks..
    Pivotal figure
    Jan 2003
    I apply the loctite inside the bb shell, otherwise it just gets scraped off as you press the cup in. For pressing the cups in I just use a Park headset press.
    Sep 2012
    Ah, thanks for the tip. Will do that. Looks like Park makes a couple of presses, which do you use?
    Pivotal figure
    Jan 2003
    Sep 2012
    Got it done - rolls nice and smoothly! Thanks for the tips kenbentit!!
    Reputation: climbingcragrat's Avatar
    I see Chris King now doing press fit BB's. Are they going to be worth the cash or should I stick to Shimano?
    Phillip
    1994 Cannondale F900
    2013 Pivot Mach 5.7
    2013 Cotic BFe
    change is good
    Sep 2004
    Shimano. I had a CK BB. Periodically lubing it was annoying especially in the winter. A Shimano or SRAM BB typically lasts a year unless you have a lot of stream crossings.
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by kenbentit View Post
    If by 'blue' you mean 242, that's not what it's for. 242 is for threaded fasteners and it doesn't do much if anything worthwhile as a bearing retainer, loctite has an entire range of products for that application. Note if you are using it with a carbon frame you'll need a primer as well.
    Pivotal figure
    Jan 2003
    That is exactly what we are using and have been for several years now. The only purpose for the loctite is to help prevent creaking, not to retain the cups in the frame...
    Quote Originally Posted by customfab View Post
    Plays with tools
    242 is a thread retainer, and isn't doing much of anything as a sleeve or bearing retainer. It's working for you because it's not needed in the first place. If you want actually creak prevention you'd be better off with a proper bearing retainer like 680. I use it all the time with great results. Or you could save the money and just use grease, it's all that's needed with a press fit that's within tolerance.
  1. Bottom Bracket Replacement Help!
    By Majestix in forum Tooltime
    Last Post: 05-08-2014, 04:00 PM
  2. Correct Replacement Bottom Bracket
    By Sylkis in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-11-2014, 11:58 PM
  3. Bottom Bracket replacement
    By mpix00 in forum General Discussion
    Last Post: 08-12-2013, 05:23 AM
  4. Bottom bracket replacement question
    By Xilikon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-30-2013, 06:42 AM
  5. Bottom Bracket replacement on X1 29er
    By ozlongboarder in forum Giant
    Last Post: 06-29-2012, 01:29 PM
Members who have read this thread: 4
