Results 1 to 7 of 7
    Single Track Addict
    Reputation: bulletboy's Avatar
    Sep 2004
    New question here. "All Mountain" Pivot Les 29'r Recipe?
    I've been a long time full suspension rider, but my brother loaned me his Les earlier this spring while my SB66c was awaiting hub parts, and I am totally smitten.
    However his Les is built more XC, and my style is more...aggressive.
    So, my question is; has anyone built one of these frames with a 130-140mm fork, "wider" rims and ~2.5" tires, and a shorter ~50mm stem?
    EDIT: IF so, how did it ride? Was it too raked out? I'm not set on the fork travel; honestly the bike took everything I threw at it with only 100mm of travel, so 120 (or 130) might be completely sufficient.
    I'm interested in keeping it light(er) but improving its ability to soak up some of the smaller stuff with the larger tires/ longer travel fork.
    Thanks,
    Chris
    Will ride singletrack for food...
    change is good
    Sep 2004
    Before you do that, maybe you should test ride something like this.
    Think this is what you're looking for
    http://twentynineinches.com/2014/06/...l-perspective/
    74 & 29 pilot
    Reputation: MTB Pilot's Avatar
    Oct 2010
    I've had my Les since December and running it with a dropper, 55mm stem, 120mm Fox Float and 2.3/2.2 tires. It comes in at 23.5 lbs and is a super versatile frame! I absolutely love this bike and it feels like I'm riding a BMX on the more groomed and twisty trails. I have however, recently, been thinking about a 29+ capable fat bike since I read the review of the Borealis Echo on 29inches.com. So I've decided to do some experimenting with the Les. While I'm rebuilding my DT Swiss XR 1501 wheels with 27/22mm rims, I'm running my Derby wides with a Knard 3.0 on front and a Bonti XR4 2.3 on the rear. I tried the 3.0 in the rear and it just barely rubbed the chain stay; Plenty of clearance on the yoke. I REALLY WISH that the 3.0 fit in the rear of my Les, cause if it did I wouldn't consider a different from for a 29+ bike. On the Derby rims the Knard measures 2.9+ and the XR 4 at 2.3+, so the rear triangle of the Les will easily take a true 2.5 tire.
    I don't think I would run anything bigger than the 120mm on the Les, but I'm sure it could handle it. This bike can take an AM role easily if you want to set it up that way.
    MTBP
    "GIVE ME LIBERTY OR GIVE ME DEATH!"
    Turn on the truth: http://www.ronpaulchannel.com/
    74 & 29 pilot
    Oct 2010
    OKAY, HOW'S THIS FOR AM?!?!
    Got the new VeeTireCO Trax Fatty 29 3.0 and it only comes out to 2.5?? knob to knob and 2.733 on the casing at 30 PSI, mounted on Derby wide rim. Deflated to 20 PSI or less, it fits in the Les rear with about 2.5 mm clearance on each side at the casing. Plenty of room for the knobs and the diameter of the tire. My frame is protected on the back of the seat post, inside the yolk and inside the stays, so I thought I'd give it a roll. F'N COOL!! If I had a couple more mm of clearance on each side, I'd really ride it, but I already ordered a Gnarvester 29+ frame. I will be keeping the Les though, cause it just ROCKS no matter what setup your running!!
    KENNY B, DAN and ARRON: PLEASE, PLEASE push CC for a Les 29+ frame!!!!!!!
    MTBP
    Quote Originally Posted by MTB Pilot View Post
    That's a very cool setup. I was just looking at the B+ Vee tire. I wouldn't mind a 27.5 version that could run those either.
    Is your fork the 44mm rake version that comes stock on the bikes? I'm wondering how that rake works.
    I've been thinking about getting a FS bike, but I honestly don't really need one. I rode my current 29er HT in Bend OR recently, and I had a great time. FS would make things a bit easier and more comfortable, but I'm not convinced I even need that yet. Maybe I should get a LES. The geo sounds cool. And I like the idea of running a big tire in front too. Very interesting. I know it would be a bit lighter than my current setup, but I wonder if the carbon could really also provide more comfort than my current steel frame??? Maybe I'm not kidding myself?
    74 & 29 pilot
    Oct 2010
    Thanks Guys!!!!! Just in time before I bought a Borealis Echo frame...
    MTBP
  1. 29er "All Mountain"/"Trail", what spokes??
    By TR in forum Wheels and Tires
    Last Post: 08-23-2013, 05:10 AM
  2. $45 repair recipe for "broken" Shimano shifters
    By Erik_A in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2013, 11:38 PM
  3. Replies: 59
    Last Post: 03-10-2013, 05:45 PM
  4. Replies: 29
    Last Post: 08-27-2012, 04:36 AM
  5. Replies: 2
    Last Post: 10-13-2011, 07:34 AM
