5.7C wheels
Printable View
  • 01-24-2013
    firehawk427
    5.7C wheels
    What do you think of the wheels that came on your 5.7 Carbons? If you changed them or did your own build what did you put on?
  • 01-24-2013
    Isildur
    I built my own, and went with Crests on DT240s. Came in at about 1500g (1514g to be exact).
    Love them! I've put them through the ringer in the last 9 months, and they've held up fantastically! Light, strong, fast, everything I could want.
    The only thing I would potentially change is to use some Flow EXs if I was going to run wider tyres than I am at the moment (currenlty got 2.35 RaRa & NoNi).
  • 01-25-2013
    ArmySlowRdr
    I changed to some Shimano Crossmax.
    edit--didn't really change. Ordered from the LBS with what I wanted.
  • 01-25-2013
    HighTitan
    Ill be putting Reynolds Carbon AM Wheels on mine when I get it. mmm carbon on carbon tastyyyy :devil:
  • 01-25-2013
    the-one1
    Shimano Crossmax eh?
  • 01-25-2013
    trek551
    Last year I bought a take off wheelset from a 5.7. DT 350 hubs 32holes, supercomp spokes and 430 rims. Then I built the hubs with CX-Rays with Lightbicycle AM rims. 1420gr of strong light stiff.
    If I were to keep the hubs and spokes I'd put Arch EX rims on it for a very good and more affordable set at 1575gr. I will not use a rim narrower than 21mm for XC and 23mm for
    Trail so DT rims are not for me.
    I bought the frame only.
  • 01-25-2013
    JMW503
    Did a full custom build and went with Enve AM's. Love the wheels. Light, stiff, and bomber.
