Results 1 to 7 of 7
    Feb 2014
    5.7c Drain hole for bottom bracket?
    Hey all, the other day when I removed the cranks from my pivot 5.7c I noticed a heap of water around the bottom bracket.
    Must get in when I give the bike a wash, down through the seat tube.
    The seems no drain hole or way out for this water?
    Must bikes I've owned have had a little hole around the BB..
    So with the pivot what does everyone do after a wash? Seems big job to remove the cranks. Maybe sit it upside down for the wash?
    Joel
    Sent from my Nexus 5 using Tapatalk
    Reputation: wilks's Avatar
    I always let the mud dry and then brush it off and wipe it all down with a wet rag. I never hose my bike down.
    I to have noticed water pooling at the bottom bracket, I don't think that all of it is from hosing it down either, it gets pretty wet where I live sometimes and all of the races that I did in the last season turned into absolute mud baths.
    Anyone have a solution? I have tried grease around the seat post to try and waterproof it but the moisture still seems to get in
    On another note, I installed a bottle cage and noticed that the threads on the bolts were really loose, this could be a possible source of the water intrusion, i am going to thread tape the little sods just to be sure.
    Chris.
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    Quote Originally Posted by wilks View Post
    +1
    Sep 2012
    I have the same situation with the 5.7 Al. I need to replace my bottom bracket because of that water. Any solutions would be appreciated. I would hate to have to replace my bottom bracket again.
    change is good
    Sep 2004
    Agree. If it's very muddy, I use a bucket of water and a brush. I rinse with the left over water by pouring over the bike but not the seat if the seat post is not sealed ie Thomson. I then wipe it down. Rainy rides or down pours with the bike on the car, the seatpost gets pulled.
  1. The screw hole above the bottom bracket.
    By TwinFalls in forum General Discussion
    Last Post: 10-16-2013, 06:36 PM
  2. Does the Mojo HD frame have a drain hole?
    By AlsTrance in forum Ibis
    Last Post: 07-09-2013, 10:50 PM
  3. 2013 29 SJ FSR Evo Expert BB Drain Hole?
    By PB Matrix in forum Specialized
    Last Post: 01-10-2013, 07:36 AM
  4. No Drain Hole on Moonlander BB Tube?
    By ferrstein in forum Fat bikes
    Last Post: 04-16-2012, 09:50 AM
  5. Remedy BB Drain Hole?
    By ruds in forum Trek
    Last Post: 02-22-2011, 11:51 AM
