Results 1 to 5 of 5
    Mar 2013
    5.7C BB92 build question
    Started my build last night on my 5.7c. The frame ame from the factory with the BB92 already pressed in. My question is when I installed the double crank and tighten everything up the crank just doesn't roll freely as I am used to on a regular BB. Nothing feels like it is grinding or out of place just feels a little stiffer. Will this loosen up or did I do something wrong. Didn't use any spacers on the crank but the instructions dont come for a BB92.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    The pressfit BB bearings and seals have a bit more drag than most BB's. You do want to make sure not to overtighten the preload nut as well.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Mar 2013
    This might sound stupid of me but what is the preload nut. I looked through all the shimano instructions on both the crank and the bottom bracket and can't find any reference to a preload nut. Is that the plastic peice that loads the non drive arm together with the drive side?? My apologize if I sound stupid here. Never had this issue before on other bottom brackets. Took the Non drive arm off last night and it still feels the same, so my assumption is that it is just stiff from packing of grease from factory and it will loosen with time. Hopefully am write and I dont ruin this thing.
    Reputation: JMW503's Avatar
    Yes, preload nut is on non chain side. You'll need Shimano's hand tool to tighten (lightly). It'll will seemingly spin more freely once you start putting miles and torque on it. All BB's ride a bit different, not a big deal - you won't notice after if not during your first ride. Take it to your LBS after a few rides if it is really sticky though.
    Pivotal figure
    Jan 2003
    I had to look on the Shimano site to see what the "official" term is for that part. It's the "crank arm fixing bolt". Now I know. Guess I have to stop calling it the plastic nut thingy
  1. BB92 ebb?
    By bzo75 in forum Singlespeed
    Last Post: 12-10-2013, 03:53 AM
  2. Shimano BB92
    By zahgurim in forum Frame Building
    Last Post: 07-30-2012, 03:46 PM
  3. HELP BB92 Question?
    By Mark Strong in forum Pivot Cycles
    Last Post: 04-27-2012, 12:52 PM
  4. bb92
    By Pivot4 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-06-2012, 10:53 AM
  5. Shimano press fit BB92 and GXP press fit BB92 the same?
    By Stryder75 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-10-2011, 04:28 PM
