Results 1 to 5 of 5
    5.7 Headset too tight
    I'm having a problem with the headset on my 2013 5.7. If i tighten it slightly it binds up creating lots of drag when turning the bars. When I loosen it to where i can turn it freely, it's not tight enough and the headset is loose. It looks as if the piece in the top part of the headset that has the slit and slides down is causing the issue but cant tell for certain.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Do you have a pic? That'll make it easier to see if all the parts are there and in the right order. It does sound like a spacing issue so I'm guessing something isn't in there or is maybe the wrong part. Just guessing right now tho....
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Old goat
    Are you loosening the stem bolts prior to tightening the top cap? Sounds like you might just need to get the stem properly seated before tightening the top cap. Make sure that you don't over torque your top bolt on the cap as you can damage the internals.
    Also, If you're comfortable doing so, pop, inspect and re-seat your headset. If you got your 5.7 at an LBS just stop by and have them take a look. Having access to the right tools is handy. They can quickly determine whether the internals are functioning properly with the headset extracted. They can also examine the headtube to make sure the headset is seating properly.
    Do you have the OEM sealed or semi-sealed headset? Or something else?
    Thanks for the replies guys. There's a Cane Creek 56 1.5"- 1.25" reducer headset in the bottom cup. Turns out the bearing was in wrong in the bottom cup. The Cane Creek was installed right side up(where you could read the words) which is actually upside down. Flipped around, all is good
    Pivotal figure
    Jan 2003
    That'll do it!
  1. How tight is too tight.....seat post clamp?
    By rsolti13 in forum 29er Components
    Last Post: 07-24-2012, 07:17 AM
  2. Headset bearing cap too tight to fit on steerertube?
    By Francine in forum General Discussion
    Last Post: 06-17-2012, 12:11 AM
  3. Headset - Stem Installation Feels Tight
    By getagrip in forum Beginner's Corner
    Last Post: 09-03-2011, 04:42 PM
  4. Bolt on skewers. How tight is to tight??
    By vizsladog in forum 29er Bikes
    Last Post: 03-05-2011, 10:25 PM
  5. Tire clearance..how tight is too tight?
    By morandi in forum 29er Bikes
    Last Post: 01-14-2011, 10:28 AM
