Results 1 to 3 of 3
    aka greyranger
    Reputation: redranger's Avatar
    5.7 c build tips
    Does anybody have any tips for headset or bb installs? Like using loctite, grease, anti seize or anything else?
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Anitseize for HS cups, Blue Loctite for BB cups. I like to install the HS cups 1 at a time just to be safe (used to press them both in at once but I've had one get crooked before so I stopped doing that). I also like to route the rear brake hose before I cable it up, makes it easier to get the ty-wrap on the guide without the der. housings in there (esp. by the shock tabs). Everything else is pretty straightforward.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Flies Higher
    Reputation: jetboy2003's Avatar
    I used carbon paste on the BB and HS. Pressed one cup in at a time, had good luck with no crooked cups. This was my first time pressing cups and it went well.
    Learn to fly...
