Results 1 to 2 of 2
Thread: 429 carbon 1X11
    429 carbon 1X11
    Want to buy the 429 carbon 1x11.
    Has anyone ridden one or even seen one?
    What size rear cassette would be the equivalent ratio of the 2nd easiest ring on a 26er?
    Any reason you would pass on this set up, other than price?
    Reputation: JMW503's Avatar
    Yes, seen the set up. I'm a Shimano fan but am impressed with the XX1. Whether or not you should get it is a matter of how you ride IMO. While you have options to change out rings depending on the day's ride ( e.g 32 on big climbing days), you'll also need a different chain. Not a big deal in my book. As for ratio's, better you go here to get ratios with wheel size: Sheldon Brown's Bicycle Gear Calculator. Second ring on a cassette will have different amount of teeth depending on number of rings and spread (ten speed 11-34 or 11-36?). That and the ratio depends on what front ring you're running as well.
  1. 1x11
    By singlesprocket in forum Eastern Canada
    Last Post: 03-06-2017, 09:40 PM
  2. Replies: 0
    Last Post: 02-20-2013, 09:28 PM
  3. Shimano 1x11... Please
    By RockyJunky in forum Shimano
    Last Post: 02-17-2013, 05:15 AM
  4. 1x11 advice
    By rbwen in forum Washington
    Last Post: 09-19-2012, 10:18 PM
  5. 1x11 vs 1x10
    By Haus Boss in forum All Mountain
    Last Post: 07-05-2012, 09:00 PM
