    Reputation: BaeckerX1's Avatar
    Oct 2007
    2011 Mach 5.7 Al shock mounting hardware size
    What size mounting hardware do you need for a Pivot Mach 5.7 Al? I'm putting on a 2014 Monarch Plus.
    Gotta get up to get down.
    LMB
    Paterfamilias
    Feb 2006
    You will need a shock that is 7.875x2.25 with 8mm hardware that has 22mm Front and 36mm rear spacing. I forget how their tuning is, but on our bikes we suggest Red sticker labeled M, and a Blue sticker labeled L for the tune. I forget if blue is compression or if Red is.
    Regards,
    "The face of a child can say it all, especially the mouth part of the face".
    Jack Handy
    Oct 2007
    Quote Originally Posted by dan23 View Post
    Regards,
    Thanks! It looks like they simplified the tuning for 2014 and only offer 1 stock tuning option to work with a wider range of leverage ratios. I'll start with that and change as needed. Really appreciate the quick response.
    LMB
    Oct 2007
    So is that M8x21.8 or M8x22.2?
    And I'm assuming the other one is M8x33...?
    EDIT:
    While good to know, I actually am being dumb. I'll just use my existing hardware. It's not a bushing or proprietary. Duh. I had a stupid moment there.
    LMB
  1. El Guapo shock mounting hardware
    By meSSican in forum Titus
    Last Post: 01-28-2013, 09:56 PM
  2. Rune V1 shock Mounting Hardware
    By freeriderB in forum Banshee Bikes
    Last Post: 01-28-2013, 08:25 PM
  3. scythe shock mounting hardware size
    By gmx in forum Banshee Bikes
    Last Post: 07-25-2011, 03:55 PM
  4. What Rockshox mounting hardware size?
    By fargone in forum Shocks and Suspension
    Last Post: 05-04-2011, 12:30 PM
  5. Shock Mounting Hardware
    By gticlay in forum Santa Cruz
    Last Post: 02-08-2011, 08:38 PM
