Results 1 to 43 of 43
    Reputation: vikb's Avatar
    Shooting in shade + sunny spots?
    Most of my MTB photography is on the fly so I can't pick a time of day when the light is ideal. I basically have to ride ahead and only have a moment or two to setup a shot. Since moving to BC I've gotten my head around shooting in low light conditions in the trees well enough for my needs.
    However what is still a problem is dealing with the frequent situation where I have partial shade and partial bright sunlight in the same shot - like shown above and below.
    My last trip featured a lot of that. [Feel free to critique anything else you think I could do better given my time/equipment limitations]
    I'd love any suggestions that you might have how to take better photos under these circumstances. My only caveat is I need to be able to get off the bike and shoot a few pictures then get back to riding fast so I can't do anything uber elaborate.
    Safe riding,
    Vik
    www.vikapproved.com
    Shooting SLR? Use of fill-flash is the answer. Enough to brighten the shadows but not overexpose the whole shot.
    Quote Originally Posted by TonyB. View Post
    The camera I use on bikepacking trips is a Canon S95 due the size/ease of use vs. performance. It has a flash which I don't use regularly, but I can give that a try.
    For my MTB day rides I use a DSLR Canon T2i which has a built in flash. Is that what you are talking about or should I be looking at a external flash?
    For day rides I can get a bit more elaborate with gear and technique since there is less space/weight limitations and the ride goals aren't as demanding - usually.
    Safe riding,
    Vik
    www.vikapproved.com
    You could try using the built-in flash. It may not be powerful enough but that will depend on how far away the subjects are. I shoot with Canon DSLR's and use 550 and 580EX shoe mount flash units. There are a few different ways to do it. Check out Youtube for "eos fill flash".
    Team Fearless Descender
    Reputation: El Salt's Avatar
    As others have said, use of flash outdoors can be helpful, but often even external (not the little built in / pop up) "hot shoe" type flashes are not powerful enough when you have very high contrast situations. Still, every little bit helps. You may need to move into "manual mode" for the best / better results. Ideally you would expose to get the highlights into an acceptable range, and then add the flash to help with the shadows.
    Something to explore, if you have access to Photoshop (many other image editing applications also have this type of tool), is the "highlight - shadow" tool. (Image / Adjustments / Shadows - Highlights...) Still using even the smallest flash to make the initial exposure, again every little bit helps. As long as there is some "meat" in your file, this tool is not going to recover something that is not there at all, you can open up the shadows, and to a lesser degree pull back some detail in blown out highlights. Just use this, or other tools like it, with a light hand, over doing it looks poor.
    BTW, you have some fantastic shots! Great use of limited depth of field here.
    "...when your ride is nearly over, it seems to have lasted but an instant..."
    Stuff
    Quote Originally Posted by El Salt View Post
    Thanks guys. I'll start using the built in flash and see what happens. Most of my tour photos are on the fly so setting up any equipment is hard, but I can work an external flash for my day ride MTB photography. I may pick up an external flash for my DSLR and start playing with it.
    BTW - that photo you linked to was taken by my friend Doug using his Olympus. My Canon S95 won't achieve DOF like that.
    Safe riding,
    Vik
    www.vikapproved.com
    Kathleen in AZ
    Reputation: DurtGurl's Avatar
    Dec 2001
    I'll second what El Salt said about post-processing... first, shoot RAW with that little S95 so you save as much info as possible. I really dislike the shadows cast from on-camera flashes and off-camera flash is too much to haul around for on-the-trail pictures, so I pretty much never use a flash. In the light and dark situaations, expose so that you are not blowing out the brights, and then you should be able to pull out detail in the shadows in post processing. I use Lightroom and am continuously amazed at what can be salvaged from sub-par photos. Not that I ever take sub-par photos...
    May 2013
    If someone already mentioned it, I apologize, but when shooting with fill flash, although you certainly can just select one of the automatic modes, I'd recommend using manual mode and meter for the sunny area. Fortunately, the dirt is probably pretty close to 18% grey in terms of tone, so you can just switch into manual with spot mode metering, center on a sunlit patch of dirt and adjust the shutter speed and/or ISO until the exposure needle is centered. Then pop the flash up and fire away. The flash's ETTL metering will properly expose your shadows, and the camera's shutter speed, aperture and ISO have been set up to properly expose the highlights. This method will generally blend the light from the sun and the flash in such a way that the photograph still looks natural. Also, since the flash is just having to punch a little bit of light into the shadows, you'd can get some pretty good range out of even a very small flash.
    Hopefully, that makes sense. If the sun's not darting in and out of clouds, you can even set up your camera at the beginning of the ride and it's good to go. Otherwise, if you don't have the time to set a manual exposure, just throw it into AV, enable the flash and fire away. The problem with AV, TV or full auto is depending on your metering mode, you can't be sure the camera will expose for the correct part of the scene, so you could end up with an over/underexposed shot, or too much flash and an unnatural looking photo.
    That Waters Guy
    Quote Originally Posted by DurtGurl View Post
    I take sub-par photos all the time and I'm amazed at what Lightroom can do with them. Simply amazed. And I can only do a tiny fraction of what LR can do, I need to work on the spot and area contrast tools next.
    For images shot raw such as yours, the fix is very straightforward and LR 5 is pretty dang cheap on a bang-for-the-bug basis.
    Rolland
    Thanks for the tips. I've been getting some better results.
    Safe riding,
    Vik
    www.vikapproved.com
    Jan 2013
    Shoot raw, then use something like Lightroom (or any other raw converter) to bring out the detail in the shadows.
    Fill from the on-camera flash can work, but it's pretty weak, so will work best when you are pretty close (though not too close because the coverage is fairly small as well). It's also directional so can make the subject more flat and to me is a bit too "obvious" as a technique.
    The bigger speedlights have more power so are more flexible. The best option would be to pick a location carefully and then use the speedlights off-camera (on stands) and use them to fill in specific areas or as key lights (by under exposing the ambient), but this is more time consuming.
    Reputation: Jamesl99's Avatar
    Jul 2013
    I'm a pro photographer (I run a wedding photography business and was a former teacher of wedding photography at a local college and have been shooting for 20+ years) - shooting outdoors is very challenging with digital sensors especially when shooting in jpeg mode as opposed to RAW typically jpeg can only support 1-2 stops of dynamic range in an exposure this means that all of the light values cannot exceed +/- 1-2 range exposure in the image without having areas under and over exposed, as seen in your first image the rider is over exposed, and the shadows are underexposed with little or no detail.
    Fill flash in these situations are typically not effective because the flashes are generally not powerful enough given shooting distances and shutter speed required to freeze motion, that said a good speedlite may work in some situations. Also if you're riding with an SLR and speedlite attached that may be a PIA to quickly stop setup and shoot.
    If you're shooting action shots your SLR would be the best choice in terms of fast image capture rather than a point and shoot.
    I would practice shooting in manual mode with your camera, and compensating for differences in your foreground and background exposures. For example a situation where you have a dark subject in front of a bright/light background the camera will tend to underexpose the image as a large amount of light is reflecting off of the light surface for example a biker riding in the foreground of a limestone cliff the rider in auto mode your camera will likely underexpose the background and the foreground this is a situation where in manual mode or using exposure compensation you may wish to overexpose by 1-2 stops.
    The opposite would hold true for a light subject against a dark background for example your first image background underexposed and foreground (subject) over exposed you may wish to underexpose by 1-2 stops.
    Keep in mind also that as you over expose and under expose areas of your image not everything will be perfectly exposed, I would focus on exposing the most important areas of the images accurately and dealing with the others in post production (i.e. photoshop lightroom etc).
    Your camera may also have a digital lighting adjustment that will automatically compensate for dynamic range try the highest setting to see if that helps as well, typically increasing this setting uses image processing power and images will take longer to save to your memory cards, this typically is not an issue unless your shooting in rapid succession.
    Good Luck, that's probably a lot of geeky photospeak so if you have any questions fire away.
    Cheers,
    James
    Moderator Moderator
    The shadow tool in iPhoto will clean a bunch of that up.
    Reputation: LTZ470's Avatar
    May 2013
    S95 is a great camera! Fill flash is great idea, but not for small camera flashes and small camera batteries on several hour rides...I use the RX1 P&S full frame and there is no comparison in Dynamic Range (Still keeping S95!)…larger sensor is the only sure way to deal with shadows and sunlight combined…simple HDR programs do work as well...
    This…
    Sony Cyber-shot DSC-RX1 Full Frame Compact DigitalDSCRX1/B B&H
    You could also use the Sony RX100 which has a much larger sensor and is comparative in size to the S95 for much better DR….and it does have Bracketing as well for even better HDR shots…
    If you do go this route buy the older RX100 not the RX100 II as the older model has much better low ISO IQ which is what most folks shoot at anyway low ISO's in decent lighting…(Don't believe all the hype about the newer sensor)…
    Great prices as well:
    Amazon.com: Sony DSC-RX100 20.2 MP Exmor CMOS Sensor Digital Camera with 3.6x Zoom: SONY: Camera & Photo
    or this…shoot three shots and stack or bracket if you like…simple HDR combining is easy and efficient with Photomatix Pro...
    HDR photography software & plugin for Lightroom, Aperture & Photoshop - Tone Mapping, Exposure Fusion & High Dynamic Range Imaging for photography
    May 2013
    I don't have the full size files so not a lot to work with…5 minutes with Photomatix Pro…
    Original:
    Jan 2013
    Stack the adjusted version over the original in Photoshop and then mask out the areas you don't want to be affected by whatever processing you used to create a blend between the two images. Like with the Photomatix version above where the adjustment looks nice on the background but not on the actual subjects.
    Quote Originally Posted by vikb View Post
    While I suppose throwing hardware at the problem (flash units, etc.) might be a better solution,
    ten seconds of editing with the Shadow tool in iPhoto generated the result here. Depends on your needs I guess. I previously have used ACDSee Pro (mac or win) that had a similar tool. Easy.
    Attached Thumbnails Attached Thumbnails Shooting in shade + sunny spots?-test_2.jpg
    Good Call Dirttime. I have iPhoto but never (think) to use it. I'm in PS, IL, and DW all day, so they are my "go to" applications. But... if you're looking for a good solid application, and one that comes with your MAC (assuming you are on that platform), iPhoto is really pretty powerful.
    Stuff
    Moderator Moderator
    Yeah, that looks good. IIWY I'd also bump up the saturation just a touch and warm up the light by a couple of degrees.
    Quote Originally Posted by dirttime View Post
    I use the shadow tool in iPhoto - lightly....I find over use does as much damage as what it fixes.
    Safe riding,
    Vik
    www.vikapproved.com
    Quote Originally Posted by Metamorphic View Post
    Fair enough. I was just trying to show what can be done by just adjusting a single slider. A lot of folks don't realize that digital cams use all sorts of algorithms to play with the raw data to produce the image they finally make available as a jpg, etc. There's nothing wrong with further manipulating that yourself, it may well be a better solution. This also shows that you are usually better off with slightly dark images than with blown out overexposed ones. Though Highlight tools can help with light areas the way Shadow tools work with dark areas, often there is not much data to work with in the too-bright areas. There is usually a lot of detail buried in those dark areas! For casual photos in less than ideal conditions, post processing is great.
    Also a good point. One thing I liked about ACDSee Pro was that the shadow and highlight tools let you pick some number of sliders for each. I think 8 was the default. So, adjusting the first one would only lighten the darkest 1/8 of the pixels, the next slider the next 1/8 etc. This lets you easily isolate the effect you are having on the overall image, and probably limits the "damage" you mention. It's been a while since I used it so I don't know if this is still the case. BTW, I'm certainly no pro.
    Sep 2013
    You dont need a $2000+ full frame camera. For what your doing you could pick up a reasonably priced Nikon D40 (or similar, slightly newer model depending of budget and availability, Canon is fine, say a 400D) which will shoot in RAW and so give you better ability to edit difficult photos. Get an older slightly cheaper DSLR, if you knock it, sctrach it or ultimatley break it, you wont be so upset and it will be less hastle to replace. Novice level DSLR's are really light and fairly small.
    The kit lens would do you just fine, but as you learn to use a DSLR you'll fine a "faster" lens will help a lot in low light, you could look for something like a Sigma 18-50mm f2.8 EX DC Lens, use f2.8 in low light and for nice blurred backgrounds, use f8 pretty much the rest of the time for nice sharp photos. You can get a copy of Adobe Elements 11 on Amazon really cheap and it will be perfect for editing your photos.
    Photogrpahy is like mtb ... theres a lot to learn and practice makes perfect, however you dont "have" to spend thousands of £'s or $'s to enjoy yourself and get great results
    Attached Thumbnails Attached Thumbnails Shooting in shade + sunny spots?-9409442370_3c88d8aee1_b-edit.jpg
    May 2013
    If you are going small the RX100 is the way to go...it will rival quite a few of the older DSLRs even with f/2.8 lens...
    Great place to compare different camera images...you can enlarge and download as well...
    Imaging Resource "Comparometer" ™ Digital Camera Image Comparison Page
    Great place to compare camera sizes and you can compare with lens on as well:
    I went ahead and put the RX100 beside the D40 to give an idea of size difference...then you have to add a lens...
    Front View: (You must turn the cameras for a side view by clicking at left side column)
    RX100 vs D40 Body
    Compare camera dimensions side by side
    RX1 vs D40: Front
    RX1 vs D40 w/ Sigma 18-50 f/2.8
    Compact Camera Meter
    gearstomorrow
    Reputation: singlespeedtoday's Avatar
    Follow the light! That's what photography is all about, isn't it?
    Often the best thing you can do is simplify. Learn how to read the light and shoot accordingly. Even shadow areas can be used as compositional elements. Embrace the situation and try to make the best of it. Adding more equipment and technology to the equation isn't always the best way to go.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    The S95 is a swell camera for actual photography! Instead of a huge zoom range (which is marketing BS) it has a decent size sensor (I mean physical size, not megapixels, which are also marketing BS) and the adjustment dials in the back and around the lens allow you to take great control over the exposure.
    When the lighting range is large, on film you'd overexpose bright parts because you could salvage a lot of that in the darkroom later. With digital it's the opposite: you don't want to overexpose anything to the point of burning, because it's more difficult to salvage. However, a lot of details can be brightened afterwards from the shadows. This kind of post-processing pretty much requires shooting in RAW format. Jpeg turns into an awful mess if you tinker with it too much.
    Fill flash is entirely viable for your main subject, which is in the center area and closest to the camera. Because the flash is not very powerful and the background is further away, it will not cast ugly shadows (like internal flashes often do indoors in poor light).
    In a nutshell:
    - Shoot RAW.
    - Consider fill-flash.
    - Expose bright parts to the limit but don't burn them white.
    - Salvage the rest in post-processing (shadow/highlight is a very easy and effective tool in Photoshop).
    If you have even a few minutes to set up the picture and maybe another person helping you, you could also use a portable reflector to brighten shadows on your main subject.
    EDIT: If you can keep the camera steady and the subjects aren't moving too much, you can use a slower shutter speed to allow decreasing ISO. Decreasing ISO has a huge positive effect on the image quality especially in the shadows.
    Reputation: AKnRDR's Avatar
    Aug 2013
    Quote Originally Posted by Cools View Post
    This is probably your best bet in conjunction with a flash you should be fine. You will find that in many situations your built in flash will not be enough. Invest in a good portable flash that can connect wirelessly to your camera. Use a medium shutter speed otherwise your photos will be to bright or dark best of luck these are always the trickiest places to shoot.!
    "If you have built castles in the air, that is where they should be. Now put the foundations under them."
    -Thoreau
    Here are a couple shots I took over the weekend using a remote flash. I'm finally starting to understand how to set up and use the dang thing. Lots of practice, but worth it! It's a huge help for shooting in the trees as long as you're willing to set it all up. Shot with a Nikon D90 and a QFlash T5D with PocketWizard remotes.
    Moderator Moderator
    Yeah, the key seems to be getting the flash low, and near the trail. Somewhere maybe 10 to 40 degrees off the line of the shot. Set up the shutter speed, aperture, and ASA to properly expose for the ambient light and mostly stop the action, then play with the flash power to get the light off the subject that you need and finish stopping the action and light the rider properly. It takes me at least a 1/2 dozen passes to get it all dialed in.
    Nice work though.
    Sep 2013
    Sound advice there.
    Massive improvement though in your photos, you're on the right track, could do with a touch more saturation to bring the colours up. If there are other mtb photographers on here dont be affraid to ask them for tips and advice ... wont be long until everything really comes together and you'll be taking stunning photos. Good luck and have fun
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    In those high contrast situations, I sometimes use a custom parameter, with the contrast set to "-1"
    Nice work though.
    Thanks! I agree on the light position. After shooting that race, I learned I need to pick up a cheap, short tripod as I was using my regular tripod on this one in it's lowest setting instead of a light stand.
    Quote Originally Posted by Ulysses-31 View Post
    Sound advice there.
    Thanks Ulysses, I also just purchased Lightroom and am starting to get the hang of that as well. There are days I'll like one effect then the next day, I'll like something else. It's a fun and fairly easy program! I actually borrowed the D90 for this one and barely used my D70. Definitely picking up a D90 body soon!
    I'm sure I'll be back on here soon with questions.
    Moderator Moderator
    There are a ton of good Lightroom tutorial videos on like. Some put out by adobe and others put out just by other enthusiasts.
    As far as the tripods go, My youngnu speedlights came with a little foot. That plus a rock or a log or something to hide the flash and prop it up seem to be more functional, plus its less to carry.
    Best thing you can do is work with the light or find different light. Get creative and work the light/shadow into the composition. If you don't think outside the box, it will hold your photos back. Brightening the shadows doesn't fix the problem, it just makes the picture look garish. Using strobes (or easier yet: reflectors) is a good way to add a ton of visual interest and set off a composition.
    John
    Sep 2013
    One thing that is always a good tool is using 'recovery' in Adobe Lightroom. It brings out exposure in poorly lit portions of the picture. I usually use flash though. Preferably remotely triggered. I get wireless transmitters and shine it on the suspect from the side to make shadows. I feel empowered when in shady spots because the sun is no longer in control of my light.
    The main problem here is choice of location, your examples show extreme conditions contrasting (extreme brights +shadows) to generate a semi decent photo. You really need less extreme light conditions and this simply means finding key places that will work as opposed that those that dont.
    When you choose a location to shoot, take your photo, and view it with the the 'histogram'. The spectrum of light captured is everything. If its shape is extreme tight humps in the centre or off-centre its almost certainly un-salvageable. You want a flat or approx bell-shaped curve for a decent photo. Skewed is OK, as you can post process anyway. But if its nasty, you know your location/light combo is poor so move on.
    Time of day and sunny/cloudy days can dictate 'when' to photographs as well. I'm always making sure I'm not shooting anywhere near the sun and use an appropriate lens hood.
    I photographed an event recently on a very bright day with 90% of the track exposed to the midday sun. I had to go out of my way to find a trail that sheltered the extreme light. A couple of examples:
    GOOD: (balanced histogram)
    BAD: (extreme histogram)
    I think your histogram photo examples might be mislabeled. The first images have clipping in them. I really don't think there is value in calling a histogram bad or good. Sometimes you want to read it to tune the exposure for a certain photo, but not to judge the photo.
    Would you say this is a bad photo because the histogram is extremely left-heavy and has a "bad" histogram?
    Photo by Ian Plant (one my favorite landscape photographers)
    John
    Moderator Moderator
    Quote Originally Posted by Slabshaft View Post
    I think its apples and oranges. We tend to think of MTB photography as one thing. But its really two things (or maybe more).
    If you page though a bike magazine what you most often see are really art or landscape shots that feature a rider in them. For those shots, like the canyonlands shot above, a shots that is technically way over or under exposed can create a level of drama or mood that's desirable. What you'll also find about those shots is that the identity of the rider is not important to the image and is often lost. I would go further an say that for one of these art/landscape/mood shots for advertising it is desirable to make the rider an anonymous person. Having the rider be anonymous allows the reader to insert themselves into the tableau more easily. You'll also find on the art shots that the rider is a very small portion of the overall image.
    But the kind of shots like lucifuge posted, or the kind of shots that I take of the kids in on the team I coach, having the rider be clearly identifiable, and well exposed is crucial. The rider is also a much larger portion of the image with the landscape being a secondary element.
    Its really 2 very different things with different ideals, and requiring different techniques.
    I'd add to that:
    - touring or long ride photography where carry a lot of photo gear and getting shots setup is unlikely, but you still want to document the trip
    - shorter day rides where there is more time to stop and setup shots and carrying some extra gear isn't as big a deal
    Often I have to ride ahead as fast as I can. Stop grab my camera compose a shot. Take it when the rider[s] behind me pass through and then pack the camera and ride fast to catch up with them. That doesn't leave a ton of time for elaborate equipment options.
    Safe riding,
    Vik
    www.vikapproved.com
    And I do agree that there is a difference. Ansel Adams always referred to the difference as snapshots vs photographs. I enjoy the latter much more. Whether the rider is key to the photo or just a blip in the landscape comes down to the vision of the person making the photo. The viewer can take it or leave it. For kid sports and a lot of mtb races, people just care that there is a snapshot of someone doing something and it doesn't look like junk. That's it and that's fine for that "genre" of shooting.
    To link this back to the OP, I think they need to decide if they are just recording something (snapshot) or making something with artistic intent and to convey emotion and a story (photograph).
    John
    Speaking for myself I'm never out to just take a snapshot - every photo has artistic intent, but I am on a bike tour or bike ride first and a photography trip second.
    On a tour in particular your available time and resources to take a more elaborate photograph changes throughout the day and from day to day.
    Sometimes I have to make a photo happen quickly and the results are less pleasing than I would like. A lot of the time those photos get deleted, but sometimes they are important enough to the overall photo that I keep them and process them as best I can.
    Other times [such as the start and end of the day] there is more time to work with and great light.
    Having spent a lot of time taking photos on bike trips I find the photos people take and how they take them is a whole story in itself which I appreciate because I know what each choice means and how it impacts the trips.
    Part of what I find interesting about taking photos on a bike trip is the challenge of working with the continually varying constraints of time, light, terrain and other riders along with the limited camera gear you can carry to end up with a set of photos that conveys a story - both individually and as a collection.
    Safe riding,
    Vik
    www.vikapproved.com
    R.I.P. DogFriend
    That's why, as I mentioned above, I think you would like the results you get from a reduced contrast setting by having a custom parameter set up just for that. You can have the custom parameter set up and ready to go, as it only takes a few seconds to switch to it, or you might find you like it there (as I do) for pretty all midday outdoor action shots. You're shooting ride shots in the midday sun and in mixed light in trees and canyons. The light is what it is and there will be extreme light, and dark areas where shadow detail will be lost with average settings. Saves a LOT of time and effort in post processing. Get it right in camera, and you won't need so much processing.
  1. Is the shade tree home mechanic dying off?
    By customfab in forum General Discussion
    Last Post: 07-04-2013, 08:55 AM
  2. Totally In The Shade!!! t.i.t.s. night ride!!! 3 sis !
    By PBR me! in forum Colorado - Front Range
    Last Post: 06-29-2012, 08:36 PM
  3. Shade Passion
    By bigworm520 in forum Passion
    Last Post: 06-29-2012, 09:06 AM
  4. Shade Mountain Trails
    By tateb in forum Pennsylvania
    Last Post: 11-09-2011, 04:42 PM
