Results 1 to 9 of 9
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    Sensor pixel density question
    Does lowering the resolution of my digital camera from say 10 mp to 6 mp result in wider sensor pixel spacing or does it just crop the sensor size? Figure someone here might know that...
    I ride with the best dogs.
    Aug 2010
    Quote Originally Posted by bsieb View Post
    Sensor size varies with design. Much more important is the lens. Most of the light hitting a sensor is broken/lost to weak optics. All of which is smoothed over by software.
    Reputation: Nubster's Avatar
    What camera? Different cameras do it different ways.
    Kona Big Unit SS
    Kona Private Jake SSCX
    DiamondBack Release 3
    saddlemeat
    Aug 2003
    Quote Originally Posted by Nubster View Post
    Nikon D5000
    Lowering the resolution usually means the camera will just deinterpolate all the pixels from the sensor into a reduced number of pixels for the processed image. You'll still get the same angle of view.
    I think the important thing here is that the sensor's pixels stay the same. You won't get better noise performance by shooting at a lower resolution. If you're having trouble with available light shots, either get a faster lens (wider max aperture / lower f/number), or get a new camera body with a better sensor and use higher ISOs.
    Advantages of better sensors compared to faster lenses is that raising the ISO doesn't reduce the depth of field like using a larger aperture does. Getting another body also means you can use all of the lenses you already have with better low light performance.
    Also, skipping a generation of sensors or two can get you 2 or 3 stops better noise performance, but it's quite hard to get that performance gain by switching lenses. You'd have to go from an f/4 lens to a f/1.4, for example. Since you can get a newer body for the price of a lot of f/1.4 lenses (or f/2.8 zooms), it's the better choice.
    On another note, some of the Nikon FX cameras can automatically go into a crop mode when you attach a DX lens, in which case the camera only uses the pixels from the center of the sensor that correspond to a DX sensor size. On the D800, this is can actually be pretty useful since you still get 15MP images.
    saddlemeat
    Aug 2003
    Quote Originally Posted by Kanik View Post
    This is why I asked, it came up in a discussion and I was curious. I don't have any particular low light problems with the D5000. When I look at my digital images from 15 years ago there is a certain punch present in those old 2.3mp CoolPix 950 images from the pre-dslr age.
    Reputation: zonoskar's Avatar
    Oeps, wrong thread.
    Oct 2011
    All it will do is provide you with smaller-sized files. That's it.
    This is both good and bad...good because it'll take less space on a hard drive, but bad because you won't be able to print as big.
    Quite frankly, hard drive space is cheap, so I always shoot everything on the highest possible resolution.
    Also, it won't do anything to pixel density or pixel pitch (related measurement) on your sensor.
    Reputation: adonis_abril's Avatar
    Jun 2012
    Always better to have more resolving power in your sensor but it will also expose any optical flaws of your lenses...it's almost always better to have fine optics than it is to have better sensor.
