Results 1 to 3 of 3
    May 2013
    DIY Go Pro mounts
    I have acces to a bunch of Go Pro camera's through my work. next week me and my family will go on holiday to the austrian Alps to do some riding and hiking. I have 5 go Pro cams with me and did some handwork to made some mounts for these nice cams.
    i used carbonfiber and aluminium strips. tools like saw , dril and file is more than enough.
    here are the results.
    after checking the mounts i made a small trip to do some offroad testing withthis result :
    I have some doubts about the rear axle cam .. i might make a mount that will bring the cam a bit lower..
    Jeroen.
    Reputation: gmats's Avatar
    Apr 2005
    Aloha, nice work.
    Regarding the seatpost mount, a little lower is nice, I like seeing the rear wheel go though it's travel and tacking.
    I actually like the rear axle angle because it can be used for alternative views when you're doing your edits.
    Also have built a mount to hold the camera out from the left side of the down-tube forward. Able to see the trail ahead (with a rider in front of you) as well as the fork going through its travel.
    Keep it coming, great work.
    Sorry for the lousy phone pics. . .
    DIY Go Pro mounts-20140908_212542.jpgDIY Go Pro mounts-20140908_213110.jpgDIY Go Pro mounts-20140908_213243.jpg
    The Under Seat Mount was made from a Topeak Seatbag Mount that was cut apart and a Tripod Mount was bolted on.
    The Hand Grip (Grenade Grip Rip Off) was made from a broom handle sanded down to fit into a lock on grip then drilled to mount another tripod mount. Not as stable as a longer pole but for things such as walking around conventions or doing quick pans in tight brush it does the trick.
  1. Mounts
    By crazychimpjimbo in forum Lights DIY - Do It Yourself
    Last Post: 04-25-2013, 03:22 AM
  2. Mounts for a new fox shock
    By MXRider72 in forum Shocks and Suspension
    Last Post: 09-16-2012, 05:42 PM
  3. I like the PMW low mounts, but...
    By MDEnvEngr in forum Frame Building
    Last Post: 02-04-2012, 10:47 PM
  4. RAM mounts
    By BiciMapas in forum Videos and POV Cameras
    Last Post: 08-22-2011, 05:28 PM
  5. frustration mounts
    By jparman in forum 29er Bikes
    Last Post: 04-27-2011, 11:24 AM
