Page 2 of 3 FirstFirst 123 LastLast
Results 101 to 200 of 292
  1. #101
    Reputation: charlichin's Avatar
    Dec 2010
    Hi again,
    Im here again. New decoration and wheels, but Im going to do they again, because Im not convinced.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-proto8copia.jpg
  2. #102
    Reputation: monkei's Avatar
    Certainly looks pretty aerodynamic!
  3. #103
    Dec 2010
    Quote Originally Posted by monkei
    Thanks, it really does.
    Im starting with the componentes for the bicycle.
    Im going to use a profile rim on the front instead the one it has now, so I have designed the front hub. I have to cut the axle, because its too long.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-bujedelantero1copia.jpg
  4. #104
    Dec 2010
    Front wheel almost finished:
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-ruedadelanteracopia.jpg
  5. #105
    Dec 2010
    Mounting the wheels on the bike. The rear one is not finished but I wanted to see how it looks.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-proto10copia.jpg
  6. #106
    Dec 2010
    Well, while I finish the current project Im starting a new one.
    This is the Charlie War Low Rider. I hope you like it.
    Greetings.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render4copia.jpg
  7. #107
    Dec 2010
    This is how its going :
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render8copia.jpg
  8. #108
    Bike Freak
    Reputation: jgerhardt's Avatar
    There is a fine line between trying to exhibit your work in such a way that it does not get stolen, and obnoxiously plastering your water mark over your work in an extremely distracting way.
    My bikes [Fe][C]ycles
  9. #109
    Dec 2010
    Quote Originally Posted by jgerhardt
    Sorry, youre right. I have to modify the watermark.
  10. #110
    Dec 2010
    Well, with the modified watermark, here is the last update of the Low Rider:
    - Crankset and pedals.
    - Front tire with thread and brand (Warstone).
    - Brake discs.
    - Rim colour.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render11copia.jpg
  11. #111
    Dec 2010
    Rat Rod style:
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render12copia.jpg
  12. #112
    Dec 2010
    New background and lights.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render13copia.jpg
  13. #113
    Framebuilder
    Reputation: Live Wire's Avatar
    Sweet design!
    If Jesse Rooke built bicycles, they would look just like that!
  14. #114
    Dec 2010
    Quote Originally Posted by Live Wire
    Sweet design!
    Thanks. Yes, I was inspired by one of the Rooke models.
    Here you have new images with the wheels almost finished and the dropouts:
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render14copia.jpg
  15. #115
    Dec 2010
    Hi, this is my new wallpaper:
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render19copia-copia.jpg
  16. #116
    Framebuilder
    What's your thinking about how the rear wheel is driven on the chopper? Friction drive with a rubber snubber hidden in the drum/2nd bottom bracket?
  17. #117
    Dec 2010
    No, it would be a second belt from the 2nd bottom bracket to the left side of the rear wheel.
    Inside the 2nd BB box there is a Rohloff, so it would have two cogs; one in the normal position and the 2nd one instead the brake disc fixed with 4 bolts to the Rohloff cage.
  18. #118
    Dec 2010
    Two more images:
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render20copia-copia.jpg
  19. #119
    Dec 2010
    Well, I have decided to remove the rotors because I think that the best way to stop the bike is mounting a small rotor in the left side of the gear box, next to the cog.
    I have also changed the colour of the paint to match better with the style (red wheels and white tire side).
    From now, Im going to start modelling componentes for my next project, so Im not going to post too much untill I start with the frame.
    Greetings from The Netherlands.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render22copia.jpg
  20. #120
    Dec 2010
    Hi again.
    This week I have been working in a new bicycle: a hardtail titanium 29er.
    This is how its going.
    - BB30.
    - Black Cat dropouts.
    - Chris King hubs (I have to put the rear one in its place).
    - ZTR Crest rims.
    - Easton EC70 bar and EC90 seatpost.
    - Thomson Elite X4 stem.
    - White Industries SS chainset.
    I have to model the brake set (probably Hope) and the chain and pedals.
    I hope you like it.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render11.jpg
  21. #121
    Wow!!!
  22. #122
    Dec 2010
    Monday update.
    I have installed the end caps, the headset and the rear hub: its a Rolhoff Speedhub, in black, to match with the bike.
    I have to model again the rear spokes.
    I have changed the headtube and the seatposttube (because it had a colour difference) .
    When I have time, I will start with the brakes, but I have decided the model: Hope Tech X2.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render17.jpg
  23. #123
    Dec 2010
    New update.
    - Rear spokes.
    - Rear disc.
    - Rims decoration.
    - QR.
    - Fork decoration.
    - Brake levers.
    - Chain.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render24.jpg
  24. #124
    Dive Bomber
    Reputation: jackspade's Avatar
    My main problem is I never know how to animate chain movement.
    Do you guys know how?
  25. #125
    Dec 2010
    Quote Originally Posted by jackspade
    Me neither, but with Rhino its impossible.
    I think that with inventor its possible, but for the moment Im not going to try it.
  26. #126
    You need to check the chain lines on the Rohloff and White cranks. The White cranks are very narrow. Pauls would be a better fit IMHO.
    Tim
  27. #127
    Dec 2010
    Quote Originally Posted by TimT
    Tim
    Good to know. Thanks. I have to model the Paul crankset, but for the moment, I have almost finished the bike.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render29.jpg
  28. #128
    Dec 2010
    New colour and new fork bridge:
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render31.jpg
  29. #129
    Not to nit pick but White cranks are not out board bearing cranks. Also would be nice to see how you worked out the shifting and cable routing of the Speed hub.
    Tim
  30. #130
    Dec 2010
    Tim
    I know that, but I like the touch of the bearings cups in mango. I have to look for a nice crankset for this kind of BB set.
    The shifting is using a Tune Rolf and the cable routing is going to internal through the down tube to the BB and from there, folowing the left chainstay using cable stops designed by me.
    Its going to be a bolt attached to the frame, but the head of the bolt has two cable stops one over the other one, so if you want to use the bicycle as a SS you can remove this cable stops.
  31. #131
    Dec 2010
    Well, although I have to finish some details, Im going to leave this project in stand-by.
    But first, I have rendered a few images.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-copkitoscuracopia.jpg
  32. #132
    Dec 2010
    Hi. As a request from a guy in the foromtb.com, I have changed the decoration of the bicycle, including paintjob and components.
    Im also learning how to model more complex surfaces by doing a new saddle for my fixies.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-copkitclaracopiapeque%F1.jpg
  33. #133
    Dec 2010
    Second version of the saddle, with a different cover and the provisional rear plate (I have to do it again bigger).
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-sanmarcorolls5.jpg
  34. #134
    Dec 2010
    New project in process:
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-chubhub1.jpg
  35. #135
    mtb
    Reputation: aintnothang's Avatar
    Im diggin your designs.
  36. #136
    Dec 2010
    Paint job and decoration finished. I have also finished the rear wheel.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render7.jpg
  37. #137
    Dec 2010
    Bullhorn...finished:
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-bullhorn1.jpg
  38. #138
    Dec 2010
    Well, today I have modelled the saddle (San Marco Aspide), installed the rear wheel, the handlebar and the saddle. I have to finish the stem, and start with the drive train.
    Im thinking in modifying the rear end to make it thicker and stronger, because compared to the fork, it looks very weak.
    For the front wheel, Im not sure, but I have to decide between a 4 spoke Corima, and Aerospoke or a traditional wheel with the front Chub Hub, and the H Plus Son Eero rim.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render14.jpg
  39. #139
    Apr 2005
    Hmmm, trying to imagine how I would model that bar wrapping. Pretty amazing work.
  40. #140
    Dec 2010
    Quote Originally Posted by MrCookie
    I have tried different things to get the way to do it. Its pretty easy but you have to follow some steps.
    I have finished the front wheel: Chub + HPlusSon, like in the rear wheel, but with 24 spokes in radial configuration instead 32 spokes with 2 crosses.
    I have also decorate the saddle a bit more with the name of the model (AspideTT).
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render16.jpg
  41. #141
    Dec 2010
    This is an assignment for a Spanish framebuilder (XCLUSIVE bikes).
    I have modelled 4 frames to show to the customers the virtual results of the building.
    First of all I wanna show you the Titanium CX Frame:
  42. #142
    Dec 2010
    CNC dropouts, handjob, headbadge, dropouts shields and cross-bridge (representing the brand), and paragon cable hangers.
  43. #143
    LOVE the rear brake barrel mounting!!! That is so cool. How will that be manufactured??
  44. #144
    Dec 2010
    From a titanium block with a CNC machine, I guess.
    The framebuilder is making some prototypes in a 3D printer to check if everything is OK with the parts, and Im designing some new parts for him.
  45. #145
    Dec 2010
    By the way, the second frame is a lugged road carbon frame:
  46. #146
    Dec 2010
    Hi, again. The third frame from Xclusive is a 29er carbon frame.
  47. #147
    Dec 2010
    I haven't really followed this thread much but it is very cool...how many of these designs actually turn into a real bike?
  48. #148
    Quote Originally Posted by sasquatch rides a SS
    Didn't CWD design your brown bike? Lol, just messin' wit Sasquatch!
  49. #149
    Dec 2010
    Funny man..
  50. #150
    Funny man..
    I try, but usually fail. I'm buyin' you dinner some day for being such a good sport.
  51. #151
    Dec 2010
    Quote Originally Posted by Mountain Cycle Shawn
    Get me a bag of Jack Link's beef jerky and we'll call it even.
    Look at me fall for this stupid sh*t
    <iframe width="640" height="390" src="http://www.youtube.com/embed/SYOcLd2wnDw" frameborder="0" allowfullscreen></iframe>
  52. #152
    That's hilerious!
    Ok, PM me your addy.
    Click the mountain bike one at the end of the one you posted, it's funny.
  53. #153
    Dec 2010
    That's hilerious!
    Oh man that one's hilarious I didn't even see it. I remember it on tv though, it was one of the first commercials years ago. And man, I was just kidding. I don't need you to send me anything (I would appreciate a steel 29'er SS 22" frame, though), I enjoy the funny remarks. Check out the thread I started on where people's names come from. You'll learn a bit more about the name
  54. #154
    I didn't know there were so many of those commercials. Yeah I read that thread, pretty funny.
    Just so you know, I only give people a hard time that I like, respect, admire or look up to. everyone else, I just tell to eff off.
  55. #155
    Dec 2010
    Thats a really funny TV add.
    BTW, talking about 3D modelling, here you have the fourth frame I have modelled for XCLUSIVE.
    Its a mini-velo for 20" wheels, horizontal dropouts, S&S couplers, gates belt ready, integrated seat clamp...
    I think it could be a nice city bicycle for people who live in small flats or for travelling with it in the luggage...
    Greetings from Spain.
  56. #156
    Framebuilder
    Your designs look great, I like these last few paint schemes. Don't know if it matters, but you might want to offset the rear drops towards the inside for a more realistic rendering.
  57. #157
    Dec 2010
    Sorry but I dont understand exactly what you mean, can you explain it?
    Thanks.
  58. #158
    Framebuilder
    Quote Originally Posted by charlichin
    Thanks.
    You bet.
    The last few frames you posted have the dropouts offset to the outside of the chain/seatstays. Check out pics of bikes with drops that attach with a "hood" like those, the dropouts are all offset to the inside, that way they avoid possible chain/cog interference.
    It's a minor point for your pics I suppose, I don't know how realistic they are supposed to be or if these are all just concepts that will never actually be built.
    Either way, the pics are great....I've been thinking of adapting the green mtb on the first page to work in steel
  59. #159
    Dec 2010
    You bet.
    Ok, I know what you mean, but the last 4 frames Ive posted were an assignment from a framebuilder, here in Galicia.
    The design of the dropouts is a brand characteristic so its his design. I guess he has studied the interference with chain and cogs.
    Actually, he made some 3D prints to be sure of that.
    Thank you anyway for the advice.
    Kind regards.
  60. #160
    some great models and renders on this thread. My suggestion for modeling application is PowerNurbs plugin for 3D Max
  61. #161
    Jan 2011
    You make visually really good designs! How much do you think about frame geometry, measurements of the parts, aerodynamics, comfort and other issues, or do you just remodel existing bikes with your own visual ideas and part combinations?
    In other words, do you do any material science, considering strength and durability of parts? Or is just visualisation?
    Anyway, please continue posting your designs! Always nice to see them.
    One car less.
  62. #162
    Dec 2010
    Quote Originally Posted by Snow leopard View Post
    First of all, thank you for your words! Its nice to receive support from you, guys.
    Normally, Im using geometries and measurements from existing bikes, but modifying some of them.
    Regarding the mechanichal design, Im trying to improve my skills about that, and Im trying to learn how to use Linkage to model an efficient FS frame.
    But for the moment, Im finishing my studies and I have no time to start any project.
    Ill let you know when I start a new frame.
    Kind regards.
  63. #163
    Charlichin - These are amazing designs and renderings! Thanks for sharing.
    I'm a long time Rhino 3D user...are you using T-Splines for some of these organic details, or just nurbs?
  64. #164
    Dec 2010
    Quote Originally Posted by DirtDiggler View Post
    Thanks, Dirt.
    I ve just used NURBS, but lately Ive installed TSplines, and Im playing with it, so my next frame is going to be more organic.
    Kind regards,
    Charlie War.
  65. #165
    Nice bikes. Post more if u have some. Im in process of making 3d model of DH bike, maybe i will post it here in next weeks...
  66. #166
    Dec 2010
    Quote Originally Posted by 666Shifty View Post
    Thanks for refloat the thread.
    Ive been very busy the last months with exams and reports...but Im starting with Rhino again.
    I have to practice to recover my skills, so for the moment Im modelling anoooother steel track bike.
    The frame is almost finished and I think that its going to be in this colour with black components (seatpost, stem, bars...).
    What do you think?
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-render12.jpg
  67. #167
    Dec 2010
    Here is a render of the dropouts. You can see the hole for a tensioning bolt; something very useful, at least, for me.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-dropouts.jpg
  68. #168
    Dec 2010
    New paintjob for the fixie frame, and the cut in the right seatstay finished.
    Im also playing with a plugin for the Rhino to build organic shapes (such as carbon frames...), and here you can see a sample.
  69. #169
    Pro-E???
    I think his models are made with Rhino, dude. Rhino is a Nurbs modeler and doesn't translate well to PRO-E. All the parts would have to be separate and you would have to rebuild somehow in an assembly. Good luck with finding the CAD work......I remember school...good ole times ; )
  70. #170
    Dec 2010
    Pro-E???
    Im sorry, but he is right.
    I would like to help you somehow, so please, let me know...
  71. #171
    Dec 2010
    Im starting again with Rhino after some weeks doing nothing, so this is my new project. I hope to finish it.
    Columbus steel Lo Pro:
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-frame4.jpg
  72. #172
    Dec 2010
    The Lo Pro is almost finished.
    Ive changed the seatstays design and the frame colour.
    Im going to replace the rear hub with a Phil Wood, because the Chub is a bit chunky for this kind of frame.
    The rims are Velocity Aerohead (650 front, 700 rear).
    Nitto RB021 with Nitto stem and Campy Record seatpost.
    San Marco Rolls.
    SG75....
    I hope you like it.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-bici4.jpg
  73. #173
    Dec 2010
    (Almost) finished!!!
    New rear hub, new handlebar (Nitto B211AA), CB Eggbeater 11 pedals...
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-bici9grande.jpg
  74. #174
    Dec 2010
    Another view and a detailed pic of the crankset and pedals:
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-bici10grande.jpg
  75. #175
    Nemophilist
    Reputation: TrailMaker's Avatar
    Gee;
    That is most impressive, and I am jealous. I would love to be able to do that, just for my own pleasure if for no other reason. Still, it is at least partially pleasing to look at yours!
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
  76. #176
    Dec 2010
    Quote Originally Posted by TrailMaker View Post
    Gee;
    Thanks, mate!
  77. #177
    Dec 2010
    New, and more classic decoration.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-smallgreen3.jpg
  78. #178
    Dec 2010
    Playing with lights, material...
    I have also modelled a Brooks Swallow (not finished yet) that fits better with the rest of the bicycle. New colour too.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-smallblue1fondo.jpg
  79. #179
    Spice
    Dec 2008
    What software do you use for the rendering? I'm using Keyshot Pro, turns out with incredibly realistic renderings
  80. #180
    Dec 2010
    Im using Vray for Rhino, but if I could get better results with other sw, it would be great.
    Maybe I could use an external program importing the Rhino model.
    Any suggestions on how to do this? And what is the best rendering sw?
  81. #181
    Dec 2010
    First rendering using a HDRI file applied to an spherical surface around the scenario.
    I have to try some mods to fix the strange reflections on the white background.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-smallred3fondo.jpg
  82. #182
    Nemophilist
    Hmmm...
    I'm not quite sure what it is, but that one looks virtually like a photograph. More so than the others. Maybe it is the background? It may break the tension of a static background and look more alive, less canned. Just not sure, but it was an immediate impression. I don't particularly like the front tire breaking the border, at least in that fashion, but the overall piece is REALLY good.
  83. #183
    Dec 2010
    Hmmm...
    Thanks, mate. Im really happy with my progress using HDRI.
    Im thinking about using a different background, maybe a wall or something like that...
    Lets see waht happen.
    Stay tunned...
    Charlie War.
  84. #184
    Spice
    Dec 2008
    Quote Originally Posted by charlichin View Post
    I'm not that experienced with rendering software only having used Keyshot 2 Pro myself, but it is extremely simple to use, everyone I know who has tried it has stuck with it. Rendering time's are quick, materials look realistic and everything is as straight-forward as possible.
    Here's a review
    KeyShot 2.0. All the Raw, Realtime Render Speed You Can Squeeze [Review] - SolidSmack.com - SolidSmack.com
    Quality wise, the best i've seen is Bunkspeed Shot- although I use Creo/Pro Engineer which is not compatible with bunkspeed, so cant comment of its interface as I have never used it.
    Bunkspeed Steps it Up a Notch with Shot Pro [Review] - SolidSmack.com - SolidSmack.com
  85. #185
    Dec 2010
    Quote Originally Posted by joehspicer@msn.com View Post
    Here's a review
    Keyshot looks really good. I should try it.
    Meanwhile, here you have a new rendering. Same model, same Vray configuration, same lights but different background.
    I hope you like it.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-smallred4fondo.jpg
  86. #186
    Dec 2010
    New project. Just starting out.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-frame1.jpg
  87. #187
    Is that a folding bike? I have worked on the first two prototypes to what eventually became the mezzo range of bikes possible the most difficult bike to design is a folder
    Just noticed is that a gboxx mount?
  88. #188
    Dec 2010
    Quote Originally Posted by ade ward View Post
    I agree. You have to check eveything, opened and folded, and check it again.
    But I think its going to be a nice bike.
    And, not, its not a Gboxx mount, but something similar.
    Here you have the rear triangle, but its no finished yet.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-subframe.jpg
  89. #189
    Pinion?
  90. #190
    Dec 2010
    Pinion?
    Bingo!
  91. #191
    I was interested in this but they were not forthcoming with any more details than on the website,
  92. #192
    Dec 2010
    You are right. I was lloking for some extra info, and its almost impossible.
    Here you have a new pic, with wheels, saddle and bars.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-bici3.jpg
  93. #193
    Dec 2010
    Well, as ade ward advised me, a folding bike is one of the most difficult things to design in this field.
    So, while I figure out how to solve the interference between frame and subframe the Pinion Brompton is in the fridge. This is my last model.
    I used some things from the other Brompton, but the rear end is completely new, attached to the frame from the inside, so its narrower than the original B one.
    Its for 120 mm rear hub, and, yes, its a fixed gear, but Im thinking in a front brake.
  94. #194
    Dec 2010
    Well, since the fixed gear Brompton is almost finished, Im starting a new project.
    NAHBS 2012 was very inspiring for me, so here you have a teaser:
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-teaser1.jpg
  95. #195
    Charlichin -
    Great job on the designs and 3D work! I love looking at what you create. Are you and engineer or an industrial designer?
    For a render engine I would give 'Flamingo NXT' a shot: Download Current Beta - Flamingo nXt
    It's FREE right now and the results are on par with some of the best renderer's. It also integrates directly into Rhino. I've used Keyshot (which is great) and some others but prefer Flamingo NXT. If you used the old Flamingo(which was terrible) this is nothing like it. They re-coded it from the ground up.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-levers.jpg
  96. #196
    Dec 2010
    Thanks for the hint. I will give it a try.
    Meanwhile...
  97. #197
    You got it, buddy.
  98. #198
    Dec 2010
    Im playing right now with Flamingo, but I have to learn how to use it properly.
    For the moment, Im still with VRay:
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-bike2.jpg
  99. #199
    Dec 2010
    While I finish the cargo trike, Im starting a new project.
    New wheels for a new frame.
    Stay tuned.
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-bujedelantero.jpg
  100. #200
    Dec 2010
    Well, since I had a problem with the Rhino file, I had to model the wheels again.
    I also lost the frame I had modelled for using these wheels (you can see the picture and give your opinion on that).
    Attached Thumbnails Attached Thumbnails 3D bicycle and frame design-delantera1.jpg
