    White Clay / Middle Run
    I was looking for the map, but I found it.
    Mike
    Reputation: 2004sahara's Avatar
    I'm headed there this weekend.
    Nickel Havr
    Reputation: Eckstream1's Avatar
    Just to add it here for future reference...
    Trail Map (PDF)- http://www.destateparks.com/download...clay-creek.pdf
    Description of trails- Trails in White Clay Creek State Park
    Quote Originally Posted by William Blake
    Great things are done when men and mountains meet. This is not done by jostling in the street .
    Apr 2005
    There's also the KenCox trail map for WC/MR/JM: http://www.kencox.net/wcc_middlerun_map_2.3.pdf
    The difference is, the DE map shows all trails (well, actually not all, see below) hiking, MTB and horseriding, and you have to look at the legend to see which ones are open to MTB-ing. Also, Middle Run is under served on that map, supposedly because it is a county park operation, and the map is for the state park operation.
    The KenCox map shows only trails open to MTB-ing. and it is somewhat more accurate. Example: Look in the upper left of both maps, note that the Cart Path trail is shown only on the KenCox map, not on the DE map. It is normal to ride a clockwise loop to combine the Cart Path and the Boundary Line trails, but you wouldn't know that from the DE map. Another example is the Cork Screw trail and the connecting Mt Goat trail, not delineated at all on the DE map.
  1. White Clay/ Middle Run ?
    By bankofdad in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 07-29-2011, 09:06 PM
  2. Is Middle Run, White Clay, etc Rideable NO!
    By Manicmtbr in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 03-08-2011, 06:31 AM
  3. White clay creek/Middle run map?
    By trrubicon06 in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 12-04-2009, 07:27 AM
  4. White Clay/Middle run???
    By WindWalker in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 09-24-2008, 05:57 AM
  5. White Clay/Middle Run Conditions?
    By marks_bike in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 12-20-2007, 08:33 AM
