Results 1 to 26 of 26
    Post your tire setup
    Seeing the other thread about tires, I thought it would be a good idea if everyone just posted their tire setup. And rather than thread jack, I started a new thread.
    Front tire:
    Rear tire:
    Summer-
    Maxxis Crossmark 29x2.1 f/r
    Winter-
    Panaracer Rampage 29x2.35 f/r
    Tubeless set up.
    Nov 2008
    Front: Kenda Nevegal 2.35
    Rear: Maxxis Highroller 2.35
    Haven't ridden this combo too much yet, but so far it shreds at the wiss and blue.
    Inbred Homebrewer
    Reputation: Stick's Avatar
    Right now?
    Front: WTB Weirwolf 2.5
    Rear: Kenda Tomac Nevegal 2.35
    Light(ish), grippy, works anywhere I ride.
    Also LOVE the maxxis high roller 2.35 single-ply 'super tacky' as much as any rear tire I've ever had - EXCEPT - for how quickly they wear out!
    "mmmm....Beeeeeeer." - Homer J. Simpson
    Reputation: InvictaS1's Avatar
    Mar 2005
    2.2 wtb mutanos front and rear on my mtb
    schwalbe racing ralphs on the cross bike
    I am running Panaracer Fire XC Pro 2.1 (the red ones)
    Son is on Nevegals (2.1 F/R)
    Reputation: bwargula's Avatar
    2.35 Kenda Excavator DTC in front
    2.35 Kenda Nevegal DTC in rear
    (2.35 Kenda Small Block 8 in rear for dry, slow, technical rock crawling)
    Eastern PA
    Reputation: JustMtnB44's Avatar
    Currently running for Western PA terrain:
    Continental Trail King Black Chili 2.4 front / 2.2 rear
    They work well. Not quite as grippy in some conditions as the Nevegal 2.35 StickE that I was using before, but they roll a lot faster and wear better. And the 2.4 is a huge volume tire which I like, but also quite a bit heavier than the 2.2 version.
    Aug 2005
    29er:
    2.3 WTB Stout front
    2.55 WTB Weirwolf LT rear
    I think the Weirwolf LT doesn't grab as well as a Kenda SB8 would in the back, but the sidewalls also don't just explode.
    26:
    2.5 Intense DH (no clue what it is really, haven't ridden it yet) front
    2.3 Geax Lobo Loco TnT Rear
    They're all tubeless except the DH tire that has a DH tube in it. I use the matching Geax Lobo Loco TnT up front for days where I pedal.
    Life is Good
    Reputation: Judd97's Avatar
    Jun 2005
    I run 2.3 UST Hutchinson Bulldogs on my main bike. They can be had for real cheap and they've always worked well for me in the SW PA region.
    Get a bicycle. You will not regret it if you live. ~Mark Twain
    Bull Lock 2.35 for both front and rear. Funny how in PA everyone runs fat tires sine all we have is rocks, rocks and more rocks.
    Bull Lock 2.35 for both front and rear. Funny how in PA everyone runs fat tires since all we have is rocks, rocks and more rocks.
    I'm running 26" Nevegals but forget what size.
    When my new bike gets here at some point between the end of this month and December (who knows), I will be running a Surly Larry 3.8" front and Endomorph 3.7" rear.
    Rear: WTB Velociraptor 26 X 2.1
    Front: Panaracer Rampage 26 X 2.35
    Last, not lost.
    Front: WTB Wolverine 2.2
    Rear: Panaracer Smoke 2.1
    Reputation: JeffSkisMontana's Avatar
    Sep 2003
    Summer and Winter and....
    Summer:
    Specialized The Captain 29x2.2 Armadillo Elite Front and Rear
    Winter:
    Kenda Nevegal DTC 29x2.2 Front and Rear
    Kingdom Trails, Millstone, Waterbury, Stowe Vermont:
    Specialized S Works Captain 29x2.0 Front and Rear
    There are two paths you can go by but in the long run........
    Chilling out
    Reputation: bear's Avatar
    29er: Maxxis Ardent 29x2.4, tubeless. Last year ran Nevegal 29x2.2 tubeless and was pretty happy with it - no-fail-grippiness, but slower rolling and I wanted more air volume (bike is rigid). Stan's Flow rims (28mm wide). 20-25 PSI.
    26er: it's bi-polar....
    DH-days (Diablo, Blue Mountain, Plattekill, etc.): Nevegal 2.7 DH front tubeless, Maxxis Minion DHR 2.7 DH rear currently tubed but wish it was tubeless, on 31mm wide rims. 20-25 psi front; 25-30 psi rear.
    other-days: WTB WierWolf 2.5 Race tubeless front; Maxxis Minion DHR 2.5 Single ply tubeless rear; Stan's Flow rims.
    Last winter on the 26er I rode Intense 2.5 DH tires tubeless at 15-20 psi. Very slow rolling and heavy, but huge tire spread on the snow!
    Quote Originally Posted by JustMtnB44
    I have a similar set up, except I'm using Mountain Kings 2.4 front and rear. I had the Nevegals 2.35 F & R before and I did like their grip, but they were the slowest rolling tires I have ever used. On a ride I do fairly frequently, I rode everything a chainring higher once I switched to the MK's.
    I would like to try the Nobby Nics to see how they compare and I have also heard good things about the High Roller (F) and Crossmark (R) when conditions aren't too sloppy.
    Do You Like To Climb?
    Sep 2004
    '09 Altitude, '08 Fox Talas, '08 Easton Havocs, Fork & Shock Push'd 2011
    Retired: 2004 Slayer, 1999 Super-V, 1994 Killer-V
    Jun 2010
    I've been running Vredestien Black Panthers 2.35's ( actually measure 2.45). They haven't done as well since the leaves started falling and they rub a bit on my rear derailleur cable on hard turns. These high volumes aired down to 30/35 lbs work great for rocky single track. I decided to go narrow and lighter. I just put on a set of Fire XC Pros 2.1's. They definitely bite a lot better, but I now bounce off rocks rather than roll over them. I need a happy medium.
    Mike
    "My bicycle masters boardwalk and quagmire with aplomb."-Tom Nuttal
    The White Jeff W
    Reputation: jeffw-13's Avatar
    On the hardtail
    Front tire: WTB Wolverine 2.2
    Rear tire: WTB Wolverine 2.2
    During the wet season Kenda Nevegal 2.35 front & rear
    On the FS bike - year round
    Front tire: Conti Mountain King Protection 2.4
    Rear Tire: Conti Trail King 2.2
    No moss...
    No Gansta Lean here.
    For Trail, Syncros BHT Lightweight 2.5s Front/Rear specific treads....
    For Downhill... Intense FRO Lite 909s 2.5 f / 2.35 rear
    EWR-HE-148-11-4-97
    Microbeer's Better!
    Reputation: jonz's Avatar
    Year round with tubes:
    Front: WTB Weirwolf 2.1
    Back: WTB Weirwolf 2.1
    Reputation: Mr Cabletwitch's Avatar
    Salsa Dos Niner, Tubeless
    Front: WTB 29x2.1 Nano raptor or WTB Weirwolf 29x2.55 for all day rides
    Rear: Hutchinson 29x2.1 python
    Redline Monocog full rigid, Tubes
    Front: Geax Saguaro 29x2.2
    Rear: Geax Saguaro 29x2.2
    I ride south central PA
    Quote Originally Posted by Malibu412
    Cableb!tch: living, breathing proof you can be right and.still be a dick.
    26'er FS
    F/R: Panaracer Fire XC Pro 2.1
    29'er rigid -- my main ride now
    F/R: Maxxis Ardent 2.4, WTB Exiwolf 2.3
    26FS & 29Rigid... best of both worlds
    Reputation: Mike Aswell's Avatar
    Front: WTB Moto Raptor Race 2.4
    Rear: WTB Moto Raptor Race 2.24
    Both tubeless. Western PA. I've found other tires I liked, but durability was an issue and I tried these and have been very happy.
  1. Looking for a tire setup
    By BSG in forum Wheels and Tires
    Last Post: 05-15-2009, 06:04 PM
  2. Tire setup???
    By ssr2 in forum Wheels and Tires
    Last Post: 05-13-2009, 07:30 PM
  3. help on UST tire setup
    By TrailNut in forum Wheels and Tires
    Last Post: 10-07-2008, 08:12 AM
  4. which tire setup?
    By Projekt AI in forum Downhill - Freeride
    Last Post: 03-10-2007, 01:36 AM
  5. What do you think of this tire setup?
    By Slowjett in forum Wheels and Tires
    Last Post: 09-21-2004, 11:26 AM
