Results 1 to 27 of 27
    Reputation: Blue Bye's Avatar
    Mar 2011
    Wow, lightness counts!
    I had an eye opening experience Saturday morning when wheeling around my recently acquired 21 lb carbon fiber hardtail. This is by far the lightest mt bike I've ever ridden and my first ride on it was amazing. I simply could not believe the responsiveness and the speed was far and away greater than I even expected. The accleration also surprised me and at the end of the ride I felt fresher than I do when riding my older bike on the same loop (that bike weights a good 8 lbs more than the hardtail). I completed most of the ride with a huge grin on my face! What a great feeling
    Life is like riding a bicycle - in order to keep your balance, you must keep moving. ~Albert Einstein
    Now go take that awesome-sauce feeling and apply some reductionist science to it!!! You must be able to prove (scientistically of course) that lighter bike = faster, or it just isn't worth it...
    (/sarcasm)
    Citius. Altius. Fortius.
    Currently in Exile
    Reputation: Frozenspokes's Avatar
    Going from a squishy bike to a hardtail?
    "There are those who would say there's something pathological about the need to ride, and they're probably on to something. I'd wager though that most of the society-approved compulsions leave deeper scars in the psyche than a need to go and ride a bicycle on a mountain." Cam McRea
    It does blue bye. As much as going from aluminum to carbon. I went back to riding my carbon 25 and my Scott 29er (great bike) is gathering dust for the time being. And that is paid through the nose to build a sub 20 pounds carbon bike now. It will allow me go further and faster.
    PRETENDURO
    Lightweight bikes are great. I generally try to save them for personal record uphill time trials and race days, and instead use my 47 pound 32x20 fully rigid beast for my training rides. My average training ride sees 5,000 feet of vertical ascent on a mix of singletrack and fireroads. The wheels weigh about 6 pounds each (Surly Large Marge 65mm wide double-wall rims, shod with 3" wide DH tires), so the rotating mass becomes a weight training tool of sorts. Try to use your heavier bike as much as possible on your regular solo rides, and then when you go on group rides, take your lightweight bike and smoke the crap out of your riding buddies.
    QUOTE from MTBR.COM: You have given Brewtality too much Reputation in the last 24 hours, try again later.
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    Quote Originally Posted by Blue Bye
    I've been kicking around the idea of building a carbon frame at the end of the year, when the frame I want is available again. Can you post some pictures of your bike, I'd love to see it.
    2015 Kona JTS
    2014 Scott Scale 710
    2014 Giant Anthem 27.5
    Mar 2011
    Quote Originally Posted by Frozenspokes
    More "in addition to" rather than "instead of"
    Leopold - I like your idea a lot!
    mopartodd - I'd love to share pics, I'll get some up this afternoon when I get home
    This is a bigger determinant than the 8lbs me thinks.
    Mar 2011
    Here she is - generic carbon fiber frame, beefy manitou front fork (but also light), mavic crossmax wheels, c/f seatpost, c/f bars, xtr rear, xt front, light weight tires, titanium pedals
    Attached Thumbnails Attached Thumbnails Wow, lightness counts!-lightweight-carbon.jpg
    Reputation: modifier's Avatar
    Quote Originally Posted by Leopold Porkstacker
    I don't know if this is a joke or not?? But if it's not I would like to see how you got up to 47lbs with a rigid single speed. Post some pics. What tires are those? Old Savages? Sounds like a torturous beast.
    No it never stops hurting, but if you keep at it you can go faster.
    Reputation: turnerth's Avatar
    Aug 2010
    the vertical bar ends are a nice touch.
    PRETENDURO
    Quote Originally Posted by modifier
    Here we go, Strava GPS proof as well as photographs—we’ll use March 2011 as the example for the Strava GPS logs, as it was all about riding every day:
    http://www.strava.com/komchallenge/l.../results/march
    And the few photos I have of the bike:
    Wheels:
    front: 26"x65mm Surly Large Marge rim in front, shod with a 26"x3" Nokian Gazzaloddi and a 26"x2.75" innertube
    rear: 24"x65mm Surly Large Marge rim in back, shod with a 24"x3" Arrow Racing Wide Bite DH tire and a 24"x 3.45" Surly-branded (Innova, I think) innertube. The riding weight involves not just heavy rotating mass, but also a few pounds of Li-Ion battery packs for lighting (the lighting setups use aluminum housings, so some more weight there), and then there’s the 12V Bosch car horn under the stem, as well as tools (need singlespeed cone wrenches and stuff onboard as well as tire levers and a spoke wrench) and a spare 24"x3.45" innertube (I am pretty sure these tubes cost around 800 grams a piece). This bike has been a valuable tool for race training.
    Mar 2011
    Quote Originally Posted by turnerth
    Thanks! Form follows function. I like to be able to sit up more, it helps my back. They come off for races though!
    "2 Wycked"
    Reputation: crazy03's Avatar
    Mar 2011
    Im sure im wrong, but am I the only one that thinks fork is on backwards??
    Ahhhh...Ahhhh....it's the hammy, it's the hammy!!
    Quote Originally Posted by crazy03
    You're wrong...
    It's on correctly. See where the wheel is mounted?
    It's all about the FSR!
    Reputation: Heavy Fluid's Avatar
    Mar 2011
    I just learned this myself today. I guess some, if not all, Manitou forks are like that. Looks off at first, but it is on correctly.
    "2 Wycked"
    Mar 2011
    Here she is - generic carbon fiber frame, beefy manitou front fork (but also light), mavic crossmax wheels, c/f seatpost, c/f bars, xtr front, xt rear, light weight tires, titanium pedals
    ok ok....ive never seen a fork that looks like this, it looked backwards to me.
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Why did you cut your steerer so short then?
    Check out my SportTracks plugins for some training aid software.
    Mar 2011
    I bought the bike used and that's how it was. I had the bar ends on another bike so I went with what I had for now
    Reputation: Hand/of/Midas's Avatar
    What is your opinion on THIS fork?
    Attached Thumbnails Attached Thumbnails Wow, lightness counts!-magura_fork_full_view_600.jpg
    Reputation: Bobby12many's Avatar
    If you think a lighter bike feels great underneath you, try riding a hardtail that actually fits you properly (!)
    Mar 2011
    Quote Originally Posted by Bobby12many
    Wow, everyone's a critic huh? I think the bike fits fine, I just prefer sitting a little more upright
    Reputation: Crankout's Avatar
    Jun 2010
    Quote Originally Posted by Hand/of/Midas
    Magura makes some very nice forks. I never noticed the double arch before...hmmmm.
    Stick around if you're housebroken...
    Digital Toast
    Reputation: Zeroack's Avatar
    I have a buddy who's running a Magura on one of his many rides. He likes it a lot.
    cycle dad
    Reputation: taletotell's Avatar
    Wheels:
    Looks like a snow bike.
    High Saddle + Upright bar ends just seems to scream "Frame is too small for me"
    If you enjoy it, and its comfortable, thats all that matters. Dont mind me.... im just stuck behind my PC 8 hours a day
